OS .21 VG - Anyone running one of these?
![](/forum/images/badges/trading_plus_member.png)
TX
I need a new engine and since OS doesn't make the RG anymore was thinking of getting one of these. Anyone have one? I know OS generally makes great engines but wanted to hear about some personal experience.
FL
Me and another guy at my track have them. They are great engines. I am still leaning mine out as it only has 10 tanks on it, it could clear big jumps while running blubbery rich.
GA
Let us know how they hold up, as I am not crazy about the way they did the plating on the piston sleeve. Wish they had stayed with the ABC like on the RG and most other engines.
PA
ORIGINAL: kojak61
This lining is better than ABC.
IN
I have a friend at the race track who just put one in his 8,and he thinks it is faster than is jammin with a V-spec.
CA
It is not faster then a vspec not even in the ballbark. I have both engines and the vg is about 70% of the vspec power.
Quick breakin, idles great runs cool but NOt a vspec. Good basher, backup motor.
GA
I agree time will tell how it holds up but I was told it was nickel and not chrome they use. If so we all know about the ABN how it holds up!!!!!!!!!!!!
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
PA
ORIGINAL: kojak61
The 30VG use the same type sleeve. And it has been out a year.
TX
Hmmmm...seems like maybe I should wait and see if it's a proven technology. I've always had great success with OS but might look at Team Orion, Axial, Sportwerks, since all I'm looking for is an engine for bashing. I'd be pissed if it only lasted a gallon or two...
FL
It comes with a 2 year warrenty. If OS is willing to put that long of a warrenty on it, Then it must be durible.
GA
Can any one show me where it says chrome? No it does not say nickel but wonder why it does not say chrome maybe because it is nickel? I agree OS for me have been very reliable but all where ABC. OS took a very good engine and discounted it the RG and came out with the VG increased the price it does not come with and air filter like the RG did and has a questionable plating technique. I use to be and OS person but I think OS is going in the wrong direction.
FL
http://video1.hobbico.com/gallery/osmg2075-deluxe.mpg
This is a video for the .30vg, but they talk about the lining. It is not chrome or nickel, but something else.
PA
ORIGINAL: kojak61
VA
I'm sceptical. The VG looks like a blinged out RG with Nickel liner.
Go with the TTR PRO 21B-R instead. That one is worth rebuilding. $46 for a P/L set and $10 for a rod.
ABL may be a lot of things, looks like a nickle liner to me, but its not chrome. The 21 VG is a good running engine, it does not producre monster torque or RPM. It will get a buggy around the track in a respectable fashion. Seems like it would be a good beginners engine or for someone that wants some headache free running. Very quick breakin and very easy to needle. Doubt I will buy another one, just had to know and had the chance to pick one up fairly cheap.
Ed M.
Ed M.
GA
ORIGINAL: crazysavage
OS has always had that warranty with there engines, I know a guy who got 4 new .18 size tmaxx engines I think it was an .18 TZ before he got one that would run well enough to break it in. I think the warranty is a show of how cheap these engines are to make and replace, not how durable they are. I would buy the new .21 VG but I would not run it as my main race engine, I would use it as a back up and run it when my RB Concepts was down for maint. The cheaper engines arent worth replacing the piston sleeve and con rod. In most cases you may as well get a new one.
ORIGINAL: kojak61
You might want to do some checking as I know my OS TZ did not come with a warranty as well as I know the V spec does not. Yes most OS engines do but not all. All so if you check it is a limited warranty. Yes OS for the most part is very good on warranty replacement when there is one.
PA
ORIGINAL: 46u
ORIGINAL: kojak61
SC
why does everyone think nickel isn't as good as chrome ?... nickel in combination with silicon carbide is much harder then chrome will ever be...it's very hard to scratch a nickasil liner...because it's much harder the concensus is that the pisont will wear quicker, wich is not neccesarily true.
nickasil linings have been used in 2 stroke engines on dirtbikes / racing engines etc for many years (15+ years) honda started lining their cylinders with nickel way back in the early 90's
SC
ORIGINAL: joydude630
Will the OS 21VG be faster with a 18 CB?
Bigger CB ---> More topspeed , less acceleration
Smaller CB ---> More acceleration , less topspeed
It's a trade-off...
PA
ORIGINAL: Losi8racer
