need help
NV
![Smile](https://www.rcuniverse.com/forum/images/icons/icon7.gif)
hello guyz, hope everybody is well.. i just came into a nitro motor, its a picco 90? it has 3 glow plugs in the head??? i cant say i know how to run this motor. do i need to light all glow plugs?? tuning on the needles. this is a big motor that im not sure about. any info would be awesome....
![](/forum/images/badges/trading_plus_member.png)
It may allow the use of higher nitro. The rule of thumb is that the smaller the engine, the higher nitro you can run. Believe it or not, nitro is considered a slow burning fuel, kind of funny when you consider that we have the little engines cranking out 38-42,000 RPM. In the "big-block" .90's the 2- or 3-plug heads help to give you a better fuel burn so you can run more nitro than you normally would. We're seeing this also in everything from Top Fuel and Funny Car engines to the little 2.3 Liter in my Ford pick-up using 2 plugs per cylinder.
NV
ok i started and did some tuning, found out the carb is kinda messed up. does anybody have a spare picco .90 carb and the little set screw that goes in the plate to hold it in place? let me know how much so i can get my friends boat running good.. thank you ron o for all ur help, u rock bro!!
