Falcon Vs Hot Shot.
Falcon Vs Hot Shot.
Which is the better Tunnel Hull, the "Thunder Tiger Falcon 3.5" or "Dumas Hot Shot Sprint 3.5" (ABS plastic version)?
Which would go faster with a "K & B 3.5cc" engine?
Thanks, Hayden.
Thanks, Hayden.
Falcon Vs Hot Shot.
i dont know about speed but the falcon looks better in my opinion. the engine for the hotshot is a K&B 3.5 (not included) and the falcon has ttr's 3.5 on it (included). if you have an engine already then go with the hot shot. if you dont have an engine get the falcon. hope this helps
Falcon Vs Hot Shot.
Yes, I already have the "K&B" engine. The "Falcon" is available with or w/out engine. I know the "Hot Shot" was designed for a "K&B" and the "Falcon" was ment for their "TT OB", but how would the "Falcon" go with a 'K&B" on it.
Would they both be similar in speed and Handling?
Can anyone suggest a better "Tunnel", I not Fussed these are just the first I came up with. But I don't feel like Building.
How about the "Prather Lap Cat 1 3.5" is it Build?
Thanks, Hayden.
Thanks, Hayden.
Falcon Vs Hot Shot.
Prather is another hull that has seen it's prime a long time ago. I'd go for a Hopper, Villian, DPI or another newer design. Shopping at Tower or wherever you are looking will not get you a decent boat.
Try these sites:
www.grimracer.com
www.htbboats.com
http://home.earthlink.net/~namba707spec/
http://www.climateboatworks.bizland.com/
Seeing how that you are in Australia, try this one too:
http://www.fastelectrics.com/nitro.asp#Tunnel Hulls
Try these sites:
www.grimracer.com
www.htbboats.com
