Savage XL Octane
Banned
Savage XL Octane
The HPI Savage is an Award-Winning series of 4x4 monster trucks that continue to push the limits with performance, reliability and ease of use. Now with the release of the new Savage XL Octane, that level of excellence has been raised to new heights. Fans are now treated to a newly updated design of the legendary Savage platform with an awesome gasoline engine that will surprise even the most experienced drivers. The new Savage XL Octane has a host of features that throw the rulebook out and all in a great Ready-To-Run package. This revolutionary new engine will give you more torque plus longer runtime. Combined with the host of new updated performance parts to the legendary Savage platform, the Savage XL Octane will leave all other competitors in the dust!
SAVAGE XL OCTANE FEATURES LIST:
- All-new 15CC gasoline powered “Octane†engine.
- All-new ducted fan design keeps the engine cooler and more efficient.
- All-new tuned pipe matches perfect to the “Octane†engine for increased torque and overall power.
- All-new composite, triple-disc brake system.
- All-new XL truck body with scale detail and thick polycarbonate for increased toughness.
- All-new extra-strength composite roll cage increases durability.
- All-new extra large fuel tank increases the already amazing runtime.
- All-new designed alloy TVP (Twin Vertical Plate) chassis.
- Full-time shaft drive 4WD system for maximum grip, power and acceleration.
- Proven 2-stage, oversized, oil-filled shocks.
- Sealed all-metal differentials with bulletproof bevel gears help tame the massive torque.
- 2.4GHz radio technology.
- Tough dual-stage air filter.
- Heavy-duty cam-type servo saver steering system.
- All-terrain tires w/ standardized Savage 17mm Hex Hubs.
- Proven Savage XL 3 Speed transmission.
- Proven Savage XL suspension uprights.
- Machined Steel Spur Gear.
- High Torque Metal Gear Steering Servo.
- Rechargeable receiver pack and charger.
- Front and rear bumpers help protect against big hits.
- Extra tough slipper clutch for drivetrain security.
http://www.hpiracing.com/news/2012121101/
RE: Savage XL Octane
Just looking around online, it seems Most 15cc gas motors are just over 2 hp. That not bad.
Wonder if the preformance guys will bring out stroker kits and big bore kits?
I know the bigger 23-30.5cc when they are full mod with a good exhaust pipe can be twice the power of the stock one.
Wonder who will be the first to get 4hp out of one of those babies.... 3hp would still be cool
It's funny tho, my slash is only 0.7hp on 2s... So that new savage should be fast enough for most hobby guys yeah?
something is making me want to take the engine and slap it in something like a HPI MT2 just to see it go flying.
The MT2 is ludicrously fast with a .28 I'd love to see it on gasoline
My Feedback: (27)
Im thinking it would be sweet to drop one in a truggy. Maybe ill have to see if I van pick up a cheap jammin X1 and go to work with my dremel to make it fit.
Claimed hp is one thing. I want to know what kind of rpm that engine is capable of. Most gassers dont get over 15-20k (which is pushing it) so gearing might be tricky with an engine like that.
ORIGINAL: phmaximus
I don't mean to sound all doom and gloom, but I think HPI have missed the mark yet again (just like traxxas and the XO-1), sure this and the XO-1, great technical achievements, but, er....why? What was the point?
As for putting it in a truggy, yakfish, I doubt you'll want to do that unless you can also make a 3 speed gearbox fit to compensate for the lack of RPM.
MN
HP= torque x RPM / 5252 regardless of whether its a locomotive or a brushed 180 motor...HP doesn't exist except as a relative measurement from a mathematical formula...there isn't a way to directly measure horsepower...you have to measure torque and RPM and run the math on it? Are you saying the brushless motor makes 3676 Lb/Ft of torque at 1 RPM?
Foxy was more talking about the linear power delivery of an electric motor compared to the exponential power delivery of an engine. The numbers he was quote were purely hypothetical just to explain the point he was making.
I have a goped, don't know if you are familiar with those but I put a Zenoah 29rc on it recently and put a high flow air filter, and an aftermarket exhaust from ROC pipes and it will take a grown man that I am and pop the front wheel off the ground with me on it. I feel certain this engine will have loads of mods to upgrade power. I use CAM 2 fuel in the goped and would do the same here, 110 octane and mixed with synthetic oil. It runs cooler and with high compression gives tremendous hp. This is a very interesting development BUT I too fear what that 3 speed trans means with regard to level of possible rpms and also the reliability of the trans itself.
ORIGINAL: Max_Power
Source: wikipedia
Horsepower (hp) is the name of several units of measurement of power, the rate at which work is done. The most common conversion factor, especially for electrical power, is 1 hp = 746 watts.
Lastly, the moeasurement of 'torque' in your formula is highly subjective, that's where manufacturers gain their extra hp points.
Thanks for the assist anyway Steed, indeed, it was more of a theoretical point.
True, I was thinking of the power delivery curve (linear). And again, I realise its not exactly linear in reality due to physical properties, but the theory is linear, more volts=more rpm at max current.
In any case, errors and omissions on my part aside, the point being that an electric motor is making near maximum power throughout its range, as opposed to engines, which have powerbands.
I agree !!!!
however my thought is this !
it is Not really fair to compare tho...as the BL systems are much heavier and larger then the nitro systems...compare then in equal terms of power density...... in other words limit the weight of the BL system to that of the nitro and see which makes more pop........... The issue with current nitro is they are small engines.. limited more by displacement then anything else...........The technology just has not been put into the larger sized engines..
hello everyone I would like to buy octane savage used as new, I would like to know if it is delicate (differential clutch engine etc) if it has carburation problems and if the engine lasts 15 liters or more.
