Aftermarket Differential Gears (smartech)
My stock diff. gears are worn to the brink of nothing-ness for my front and rear wheels. Does anyone know any aftermarket diffs. I can put on this brand? it is a Smartech 1/10 condor pro buggy.
Here is the info I have so far:
Supposed maker of my car: Acme Racing.
Model: 2 Speed Condor Pro
Diff. Bevel Gear S. (~1/2" round, ~1/4" height, 10 teeth)
Diff. Bevel Gear B. (~10/16" round, ~1/4" height, 13 teeth)
hole size needed for my pin to fit in (~1/2")
My research has shown that the OFNA 37771 and 37772 bevel gears might just fit! I am waiting on a response from acme and OFNA to see if these will indeed fit. If they think they might, I will go to my LHS and buy a set. I will report what I find.
EDIT:
Does anyone have these gears from OFNA that could provide me with the mesurements?
On a unrelated note....
I purchased a dynamite tuned pipe with manifold set as a replacement for mine on the smartech buggy, fits with a minor mod to the exhaust pipe coming from the pipe. Has to cut it back about 1". I don't have the specific model number with me right now, but if you need it let me know!
Edit: Changed 1/2" on bevel gear B to 10/16" as that is closer to its size
EDIT:
ORIGINAL: Treader
EDIT:
EDIT:
What about that?
I have the same problem and i am looking for something alternative and more qualitative!
Please answer us!
Thank you in advance!
Go to www.rchighspeed.com and see what they have. I got some aluminum parts from them. Worked great.
