Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
 No Reverse!(Sorry for so many questions) >
Old 12-17-2006, 02:10 AM
Default No Reverse!(Sorry for so many questions)
Hi im still breaking in,if you have read my other two questions.I have just found that the car has no reverse!What can i do to fix this problem.Also it may hgave something to do with when the car is idling the wheels are spinning rather fast.How do i fix this problem also and are they suppose to spin at all when idling?Thanks. P.S I have a 4wd 1:10 scale buggy.
Old 12-17-2006, 02:19 AM
Taffey's Avatar
Default RE: No Reverse!(Sorry for so many questions)
Most nitro and many electric RC cars do not have reverse. It's a fact of life.
How do you solve the problem? Uh, well, you can start by designing a gearbox with a shifting mechanism... or maybe you can borrow one off of a monster truck or something... and then you'll need to add a 3rd servo to the chassis somehow. The short answer is: You don't solve the problem. The vast majority of the time you won't need reverse, and it would add a lot of weight and complexity to your car anyway.
With regards to your idling problem, make sure that your throttle trim is set correctly. Just try dialing down the trim to see if that solves the problem. If not, there are several other things that could be happening. You may need to adjust your throttle linkage, dial down your idle adjustment screw, or richen your low speed needle. Just start with one thing at a time and narrow down the problem.
Old 12-17-2006, 02:36 AM
Ok thanks i must sound like a newb...With the low speed needle,what do i adjust on that,the rod or the nut,how?thanks.
Old 12-17-2006, 09:20 AM
My Feedback: (33)
Not sure what you mean by the rod or nut . you don`t want to touch the low speed needle until you have set the high speed needle . The low speed needle is right where the linkage is connected to the carb . There is a screw that you turn , clockwise to lean it and counterclockwise to ritchen it . What car do you have ? Like mentioned above not many nitro rc have reverse except some monster trucks , and some electric that have reverse in the speed control . You will get better and faster answers if you mention what your rc is that you have questions about .
Old 12-17-2006, 11:51 PM
Ok,for the lsn there is a nut then a skinny steel rod like.I cant see any screw,where???I have a vh-x5 nitro 1/10 scale buggy
Old 12-18-2006, 02:29 AM
Taffey's Avatar
Is there any way for you to take a picture and either post or e-mail it?
Old 12-18-2006, 02:40 AM
Someone said that they researched my car and it doesnt have a lsn.Now when i pinch the fuel line for the pinch test i cant adjust it so the car might not turn off in 5 or 6 secs,it may take 10secs,so how am i suppose to adjust that problem?.So what am i sduppose to do for the pinch test or any other problems??/thank you.
Old 12-18-2006, 11:51 AM
My Feedback: (33)
First , did you buy a temp gun ? Second after you break-in the engine you lean the needle [clockwise] to get it to proper operating temp and then do your pinch test , a really rich setting will act like you are saying it is .
Old 12-19-2006, 12:10 AM
Yeh i bought a temp gun,but i wont be able to set the LSN per the pinch test,Because i dont have a LSN.Is this a bad thing what are the good and bad things about this???
Old 12-19-2006, 05:59 AM
most cars dont have reverse because:
A. its illegal to use reverse when racing
B. for electric motors it can damage them if u have it in reverse then just slam it into forward to wheelie. not good on the diff either!
Old 12-19-2006, 09:35 AM
My Feedback: (33)
ORIGINAL: naynay12
Just because your car only has one main needle doesn`t mean you can`t do a pinch test . The one needle will adjust the fuel flow for both low speed and high speed . Get your car tuned to proper temp and pinch the fuel line and go from there .
Old 12-20-2006, 12:38 AM
Ok thanks.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
