Nitro content
Highly debatable topic. No doubt there's a difference between 10 and 20%, bu tthe difference between 25 and 30% is not noticeable. Also, going to 30% requires you to add a shim to your engine to slightly reduce compression. In europe we have 25% fuel available everywhere, and it's hard to find 30% (well it is in Greece anyway). In the US it's the other way around, as I understand. So if you have choices between only 20%a nd 30%, it might be worth shimming the mill and moving up. It's total rubbish though, that increasing nitro percent makes the engine run cooler. It either makes a negligible or no difference, as the increase in nitromethane causes a cooler fuel, yes, but also a hotter explosion. Also, the higher the nitro, the trickier it is to find the sweet spot when tuning.
adding nitro
basically increases the
amount of oxygen
in a given volume of fuel
at the minimum
you'll have to retune
you may have to
reshim and/or change glow plug heat
the engine, contrary to popular belief
will run hotter
but yes,
if you go from 20% to 30%
and make the necessary adjustments
you should see at least some
performance increase
amount of oxygen
at the minimum
you may have to
will run hotter
but yes,
After running over 12 gallons of 30% through my stock savage 25 engine before it finally started to wear out makes me think that 30% really isnt bad for an engine at all as long as it is tuned properly. My stock 25 would wheelie the savage on demand with 30% nitro.
