Will this power supply work with this charger?
power- http://www.rcmart.com/catalog/rc-pow...ml?cPath=52_54
charger- <span style="font-size: 10pt; font-family: "Tahoma","sans-serif"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">http://www.rcmart.com/catalog/rc-bat...?cPath=52_1271
Any info will help want to find an affordable charger and lipo set thanks</span>
SD
RE: Will this power supply work with this charger?
It should as long as you don't plan on charging at more than 4 to 5 amps.
I like to have apower suply that has an amp rating of at least 2 amps more than my highest charge rate.
So if you want to charge at 3 amps, the power supply should be able to put out a minumum of 5 amps. But then again, I use a 45 amp power supply and run 2 Turbo 35 chargers. I know it is a bit of over kill but it works with less heat that way.
I recamend get the biggest, highest amp, power supply you can afford. Having too much is better than not enough. Not enough could damage your chargers.
Moderator
Also, look at the AC/DC chargers, many of them aren't any more expensive than you're already willing to spend - and simply plug into the wall. Obviously, if you need a power supply for other purposes as well this wont work, just a suggestion.
so something like this would work better?
http://www.rcmart.com/catalog/rc-bat...l?cPath=52_973
and thank you for your time
@<font color="#00265e" size="2">sheograth</font>
what ac/dccharger would you recommend in my price range and a link would be awesome thanks.
OH
ORIGINAL: SGTslaughter01
i believe that is what i am going to do im just trying to get back into the hobbie after a long time of being out not trying to spend to much money at first i dont need the best stuff out there but i dont want to mess what i do get up because i was not sure about it thanks again.
OH
Before you order you might want to check out Hobbycity as well. They have a similar charger to the one you are looking at, and just about the best Li-Po prices for very decent packs.
