FS-it4 Help Needed
My Feedback: (35)
FS-it4 Help Needed
Ok here is my problem, If you notice the throttle you'll see that the brake/reverse is on. I have went through the radio looking at everything that has to do with brake and throttle and cant find any way to set it to off or center?? If i'm missing something please fill me in... the radio came with the 1.01 US and I updated to 1.02 US when I received it.. Please help...
Let me go look at mine. Mine is centered. I have the old one where I had to replace the chip and then flash it with the new firmware. Mine has been flawless for almost 2 years now.
I know it is under one of the menu's. Just what one is the question? I know there is a throttle up for a nitro engine.
Buzz.
Buzz.
My Feedback: (35)
Buzz.
Buzz.
If you have this issue ignore the previous posts and follow these steps with the vehicle battery disconnected and the radio turned OFF.
1) Hold TR4 switch in the direction indicated.
2) Move and hold throttle trigger to full reverse.
3) Hold both switches in these positions and press the power button to enable factory mode.
4) With factory mode enabled select "sticks calibration"
5) Follow the onscreen instructions and press the "back" arrow twice. The radio will restart and you should see this screen with throttle at zero.
