Nomadio React or Spektrum Pro
Is the DSSS modulation technology available on the Nomadio REACT a fully functional (TRUE) DSSS modulation system ? Will it support the Spektrum Pro and all Spektrum Peripherals? Why does the Nomadio REACT use 100Mw of power for it's FHSS and only 10Mw of power for the DSSS? I believe that the Spektrum uses 100Mw of power for its DSSS? What are the Mbps rates, standards and limits for the Nomadio React in the DSSS mode and the Spektrum Pro?
In short, if I were looking to purchase a DSSS R/C Radio, how would the Nomadio REACT & Spektrum Pro DSSS modulation systems compare and contrast to one another?
Is the Spektrum DSM2 still just a DSSS modulation technique?
RE: Nomadio React or Spektrum Pro
The Nomadio React will drive the DSSS receiver of the other brand at the frame rate, power level and format of the other brand with our Beta software, all the current surface receivers they offer. As for the "Peripherals" the Nomadio will not listen to their "telem" unit. Hope that helps I sent you an email about this from the Nomadio forum.
The dsss TX / receivers you mention are 10Mw 50Hz frame rate
Nomadio mode is FHDSS TX/RX are 100Mw & 100Hz frame rate
