New to drift..
MN
im looking at getting a nice rc drift, somewhere under or close to 200... been looking at hpi sprint 2.. not sure yet.
help?
thanks.
help?
thanks.
WA
The Sprint 2 drift is a good starter.
Can I make a few suggestions?
1) Put 4 oz. of lead weight on the front bumper. That will even out it's weight distribution close to 50/50, and make it more controllable.
2) The rear diff cover should be removed (with a dremel, to make it easy). otherwise, you'll be replacing belts when rocks and debris get caught between belt and pulley.
3) Lock the rear diff (it doesn't come locked from the factory, I don't know why) with epoxy.
4) For the best turn-in, get a front one-way unit (HPI makes one for the Sprint 2). It also makes transitions more consistent. Usingthe stockdiff works O.K., but diff action is inconsistent.
5) I have a steering fix for the Sprint 2. (the steering has a lot of slop in it, engineered that way) in the"HPI Sprint 2 thread" in the on-road car sectionhere, at RCU, on page 34,about halfway down. Use it if you feel you need it.It's pretty low-cost, andit works! I did mine a year ago, and it's still tight!
6)Hop-ups are indeed available for the Sprint 2, but I would concentrate on the carbon parts, and suspension.
7) A good source for durable,inexpensive tires is Raikou Drift Tires. The stockers will wear out in no time, and ratherthan get tires that won'tlast any longer, and/or costas much or more, Raikous will last a looooooong time! The first set of their DXPE's I purchased more than a year ago is still mounted on my S2 andSTILLsliding! They're hardly worn, and I drift a lot! I suggest their DXPE/D68 combo pack. The D68's are evenmore durable than the DXPE's! For a couple of bucks over the price of one pair of replacement T-drifts from HPI, you can get TWOFULLSETS of drift tiresfrom Raikou!
Try them out, I think you'll be pleased.
All this might sound as though the Sprint 2 isn't that good, but on the contrary, Once the chassis is set up right, it will drift with the higher priced chassis just as well!
good advice here from gokemidoro, do the modification at the rear bulkhead #2 on goke's list before you hit the pavement and you'll be a happy camper!
here is a picture of my tricked out sprint 2, she's been sitting idle for a few years now, I don't use her anymore, not that she is a bad chassis I just keep buying cars searching for the impossible, perfection!
![](http://i851.photobucket.com/albums/ab76/njim/IMG_0735.jpg)
![](http://i851.photobucket.com/albums/ab76/njim/IMG_0736.jpg)
I covered my rear diff pulley to protect it, but the cut out mod works good and looks better.
![](http://i851.photobucket.com/albums/ab76/njim/IMG_0737.jpg)
