Ghetto Slide
Banned
Banned
Tape is cool, Then you can Graduate to ABS then Advance to PVC..
Just make Sure that the Surface you slide on aint as dirty as the street I was using.. The TT-01 Turned into a gravel truck with the amount of stones it collected.. I had to stop drifting as a Rock got stuck between the Servo and the Prop shaft..
It was good fun though
wouldn't say pvc is a step up from abs - i have pretty much the opposite problem to u guys - i can only find pvc in black and abs in white, not the other way round - was drifting on pvc first, and it was good, but when i got some abs it gave me alot more control and precision and i could stop within about 1m instead of it sliding for about 3m after i hit the brakes!!!
