Is E-3000 glue okay to use on lexan?
That's all that's available to me right now and I'm not sure if this glue is okay to use on lexan I need to install my light buckets
RE: Is E-3000 glue okay to use on lexan?
I use clear silicone - the stuff you get at home depot. It works fantastic, I saw my brother using it to under mount a sink to a piece of granite, I though if it can hold a sink up it will definitely hold light buckets in place. Make sure though that you get 100% silicone, not painters latex. You can also use liquid nails, you can get it in small tube like toothpaste size, this stuff works great too because they remain flexible so they can take a hit and not come off.
yeah but that's more than I have to spend right now =/ and I don't want to have to bother looking to see if it is a high temp or a low temp gun
