Compatibility for others?
![](/forum/images/badges/trading_plus_member.png)
IL
Have a question "pro's". I have this Fuze Brushless Programming card. Are programmer cards compatible with other systems, or only the brands they are made by?
For example would Fuze work with Castle and vice versa?
Appreciate the help,
Randy
![](http://www.rcuniverse.com/forum/attachment.php?attachmentid=1969598)
Randy
No they are not compatible unless the OEM is the same
Like for instance Hobbywing cards will work on a few different ESC's brands if they are all made by Hobbywing just labled different.
Castles programmer will work on most HPI ESC's as the majority are made by castle(there are a few Hobbywing ESC's in the mix for HPI)
But no you cant say use a castle programming card on a Hobbywing ESC as the firmware they have are 100% different.
Example (from what I read) Speed Passion OEM is Hobbywing so a Hobbywing card would work on Speed Passion ESC's
