ML01 the futur of RC cars...
![Lightbulb](https://www.rcuniverse.com/forum/images/icons/icon3.gif)
Be ready for Rc revolution.
The ML01 is, in a first step, available in 3 adapter kits.
MP9, MBX7 and XB8 (2014) be selected models for conversion.
In a second step, Tecrace rc will develop its own rc car with a near the ML01 concept
ML01 is under development for the past one year.
The prototypes are followed at a rate of one every two months.
We are now in the final phase, so we can move to the production and marketing phase.
The initial concept is to have a car with a perfect balance and an optimized mass centralization.
We have opted from the outset for a motor in the central axis of the frame right above the rear drive shaft.
If this position the location of the engine mounts, it is no problem because the engine is in the middle of the chassis.
Another originality comes from the battery trays
They can be put in lying or standing but the biggest innovation is that they can move forward or backward to distribute weights Front / rear in different ways.
The advantage of this is to simply moving the bins give more or less steering the car.
Finally, we decide to keep original parts as musch as possible, so you only need to fasten the front and rear drive train and central differential of your car to the chassis. no need to change the drive shaft of something.
The aluminum used is 7075/T6, which is currently better for your chassis and bit of manufacturers use because of the price of the material
the car will be available soon for more info:
[email protected]
www.tecracerc.com
[email protected]
www.tecracerc.com
