receiver question
![](/forum/images/badges/trading_plus_member.png)
I'm on my 4th receiver for the flysky gt3b I've pulled them apart to inspect the antenna and it all looks fine. No cuts or sharp bends on it either.
Are these receivers just that bad or am I doing something wrong? They aren't overloaded and the batteries in the remote and from ESC are all OK. The antenna sticks out and isn't all over the ground. It hasn't gotten wet or anything. Just sitting in the receiver box and that's it
![](/forum/images/badges/premium_member.png)
We had one member that had failures one after another with flysky RX's like that years ago in his case turned out the ESC was putting the full battery voltage into the ESC as it had no BEC built in...
I've had 2 go bad in my exo and one in a redcat rs10
The exo has a hobbywing sc8 with a savox 1256tg and the rs10 was just stock.
I've got my new receiver in my wraith with a MMP and some water proof 625wp horizon hobby servo. Its doing OK so far.
Symptoms are loss of range, maybe 30-40ft away from me then just dead, when I walk up to it its fine and starts going again.
if you want to look if it were me I'd look at where the antenna connects to the board, and see if the antenna wire is damaged if its properly soldered to the board. It potentially could be damaged where it bends.
I'll check it when I get home then thank you!
I didn't think about the antenna wire on the controller going bad even though it bends up and down all the time
blonde moment I guess
![Stick Out Tongue](https://www.rcuniverse.com/forum/images/smilies/tongue.gif)
Also check the antenna wire itself with an ohm meter for continuity, it may have a break. (Although four occurring at once would be weird)
How old is your servo? I've had servos go bad that caused all kinds of wierd action in the car. A bad servo can "brown-out" your receiver and cause weird things to happen, including killing the receiver.
is the problem with 4 receivers or are u only having the problem with 1 receiver?
antenna wire is different to normal wire, its a lot like coax. it has a inner core and a outer shield. and at the tip the inner core is exposed about a inch
in not saying this is the problem but its the biggest cause of range issues in all brands receivers....
the biggest problem is the tip of the wire braking off, (the exposed part) meaning that the inner core is completely covered.
here is a example of how to repair a broken tip. as u can see the outer shield has been striped back and the excess shield still needs to be cut off.
![](http://www.electroschematics.com/wp-content/uploads/2008/11/step5-24ghz-antenna.jpg)
