Need help with my exceed rc infinitive EP
So I just bought a new rc truck and my
problem is that when I’m driving the truck it cuts after 30 seconds or so.
the red light on the esc will blink and I have to turn it on and off in order to make it work again.
but same thing will happen once I drive it again.
i already turned off the low voltage protection but no result.
I’ve been trying to figure out this problem the entire day but with no results.
its driving me crazy!!
I also calibrated the throttle range settings but that didn’t do anything.
someone please help me!
Did you re-charge the battery? If using the included wall-watt charger, it can take upwards of 6-8 hours to to re-charge the pack, plus some chargers have been known to fail so you might want to double check the voltage with a voltmeter just to be sure the pack is fully charged.
