Hpi trophy flux problem
Hi all.
Pretty New to this hobby
I've got a hpi trophy flux should I presume its a 4 wheel drive.
It appears there's a problem somewhere as when going forward only the front wheels are driving and not the rears,but when in reverse all 4 wheels drive.
would this mean 1 of the diffs are gone ?
yeah that sounds very likely the issue, probably best to start taking apart the rear diff to investigate the ring/crown gears to see if they are stripped... if so you may want to shim the gears when you install replacements to avoid stripping them again:
[QUOTE=bill_delong;12745086]yeah that sounds very likely the issue, probably best to start taking apart the rear diff to investigate the ring/crown gears to see if they are stripped... if so you may want to shim the gears when you install replacements to avoid stripping them again:[/QUOTE
Thanks bill rear diff gears was stripped
