Need help with my ESC
NY
The on/off switch on my LRP AI is no good. One of the wires came off the switch. Can this be soldered back, becuase it is a really small wire. Or is there anything else that can be done?
MO
If the switch can be opened, you could solder the wire back on. Just use a low-wattage iron and a pencil tip. If it can't be opened, you could put a new switch in it's place. Or as frailcow said, just clip the wires and solder them together - when you plug the battery in, the car is on, and when you unplug, it's off.
