LRP V 7.1 Digital Speed Control Settings
I was acting like a fool and started pressing and holding the set up button quite a few times. Does anyone know of a site other than LRP (site wasn't any help) that can help me with instructions?
ORIGINAL: 45mph pede
Your esc didnt come with an instruction manual? Im sure the info you need would be in there.
-Wes
-Wes
I might register on the LRP forum and try that route. I doubt any shops will be open today.
Banned
VA
I know all of my LHS are closed. There should be a PDF some where thats a copy of the instruction manual... The question is where.[
-Wes
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
-Wes
there is a dopwnload section in the lrp website with the manuel avalable, or post a question and i will try to help.
Tom
Tom
a link to the speedo manuel-
http://www.lrp-electronic.de/e/uploa...-userguide.pdf
Okay, I got the throttle to respond by running through the steps, i ran it all the way up to full throttle and back down, let off, and went for more throttle and nothing !!!!!!! would you rule it as a speed control??? or motor? Everything is hardwired except for the batteries which are Deans plugs. my car is all wheel drive.
So I turned both back wheels manually one gear click, and tried the throttle and it worked. I ran it all the way up again, back down, and let off, and it died yet again.
Banned
VA
...thats weird...
Do you have another esc, that you could run the motor on. That way you could rule out the motor being a problem.
-Wes
-Wes
No, it was the only esc i bought. Is the V7.1 still a decent speed control? I bought all of this stuff 2yrs ago, and I know how things can change overnight.
Banned
VA
Its still a decent esc, its made by LRP arguably the best esc company out there. Is the motor just unresponsive, dose the esc light up as if its trying to get the motor going but the motor just doesnt go, or does the esc just not light up/work.
-Wes
-Wes
Yeah Wes, exactly, the motor is unresponsive, but the speed control LED's are lighting up. I think it may be a bad Trinity P2k2 Pro Motor.
No, once my LHS had it set up right, i never messed with the electronics until now when I reset the ESC.
Banned
VA
Theres your problem. Your going to probably need to get some new brushes and a good comm cut. This in total should cost about 10$ maby more. Your local hobby shop should do comm cuts. On monday you might call um' up and ask before you go to them for nothing. They will also (most likely) sell the brushes you need. If they dont then tower will sell them.
-Wes
EDIT: now trinnity makes long life brushes you might want to check into those
-Wes
to find out if its the motor, unsolder the motor from the speedo, and touch the the pos and neg terminals on the motor with the matching terminals on a battery. the motor should run happily,. yes the v7.1 is an amazing speedo, i wont be changinf mine for a while.
tom
tom
Banned
VA
The comm is on the end-bell of your motor. It gets wear on it, so you clean it, and cut it, for maximum proformace, or in your case, to get the motor going. Some people just use an eraser to do this prosses heres a link to what you need to do: http://www.misbehavin-rc.com/pit-lan...intenance3.asp and dont forget your brushes.
-Wes
-Wes
