Electric Motor Dust Problem!
![](/forum/images/badges/premium_member.png)
Hi all,
I'm new to your forum so if I error, please forgive. I have an Associted RC10 B4 Buggy kit with a motor upgrade to Speed Gem 10T. I recently found a very nice public track that is mostly fine dirt. The problem is that my motor will get dust in it after 2 or 3 laps and quit running. My local Hobby store said just to spray it with elecric motor cleaner. Does anyone have a better idea? I'd like to at least run the battery done before the car quits. Any suggestions are welcome.[&o]
Banned
VA
Hmm... I've never heard of issues like this...
Well you could get a thin sheet of lexan and make like a cover over the motor so that the dust doesnt get in, maby try a heat sink? That could keep some of the dirt out of the motor area.
-Wes
-Wes
I like the lexan cover, but I might have heat concerns. Make sure there is still enough air going to the motor.
My idea would be to make sure the brushes arent too tight in the brush hoods. I have this issue with a Fantom 19t team edition and the brushes are tight in the hoods and it makes it stick like this in the dust. I have pried them appart just a tiny bit and my problem was solved.
Make sure you know exactly what makes it quit...
Scy
Scy
Thanks Scy,
I think I will do a little more investigation to determine just what is causing this. It doesn't seem logical that this would be a problem for a car designed to run off road. If I come up with something concrete I'll post it.
Don
Don
Banned
My Feedback: (-1)
Lossen the screw on the hood a qaurter turn and spray it clean then drop a drop of oil in behind the brush and grab the brush wire and pull a tiny bit and realease.Do this over and over till the brush moves freely in the hood.Also get a heatsink anyways if your running that 10T.
Sounds like we are getting somewhere. I thought it odd that the motor would do that, so it appears that some tweaking to the motor was necessary. Will work on it today. I appreciate all the fast responses.
Well I've learned a little thanks to all of you helpful people. One suggestion was to use Com Drops (available at your local hobby store) on the Commutator. A drop from each side then run the motor a little helps keep the contact good. Of coarse spray the motor with electric motor cleaner first then I use compressed air to dry it off. A lot of gunk will come out so I spray the cleaner until it appears clean. Another thing is to check the brushes often. Mine wear out faster than my old motor's brushes. A quick fix if the engine quits is to spray compressed air to clean it out, but sometimes it just takes a good cleaning. The drops made a considerable difference.
I am having a hard time finding a heat sink to fit though. The B4 Buggy assembly has a motor cage that prohibits a standard sink. You need a narrow 4 fin clip on sink and from what I can tell they aren't made any longer. Suggestions welcome as usual.
Thanks...Tower has a ton of them. Unfortunately none to fit the B4 Buggy assembley. This is a picture of the motor cage. It has me stumped! http://www.rc10.com/enlarge/rc10b4_tranny.htm
