View Poll Results: A poll
Voters: 27. You may not vote on this poll
best motor
AB, CANADA
hey, i wanted to find out which motors you guys think are the best out of these
(p.s are some higher turn motors actually more powerful than some lower turn ones??????????????)
TX
You might want to try your poll again with a different expiration date (IE none). It expired about 17 minutes ago, so no one can vote.
But to answer your question, yes. Some 19 turn motors are equally or more powerfull than other mild mod motors (15+ turns). The reason being, is that 19t motors have been well developed because of the Spec 19 class, whereas the other mild mod motors, can't race in stock, or spec 19, and couldn't keep up in the mod class, so they haven't been developed so much. Once you get to 14 turns or less, you run into hand-wound professional-grade motors which will have more power than the 19 turns.
NY
since the v2 revolition isnt up there id go with the sv2 im not entirely sure about this motor but if its anything like its older brother its has a ton of torque and very low maintenence
heres a vid running my 10 t reedy pulse r
it was pretty cheap got it of ebay new for 15$+4 shipping
http://www.rcpics.net/img/72561
http://www.rcpics.net/img/72559
