Is it bad if my battery were to be wrapped in a thin piece of foam?
Banned
IL
Heat is the main problem. Do you guys think it would be alright if I wrapped my stick pack already wrapped in shrink wrap and wrap it again it thin thin foam like 1/16ths of an inch? Im doing this to secure the battery easily between the slots of my chassis with some sort of tie also the space it out form the aluminum so it wont short. Would heat be a concern and affect my performance? Its like a blanket but would it matter....
i believe you shouldn`t do it. heat during discharge is otherwise high, so that foam will make things worse. why would you want to do it exactly?
Banned
IL
Hmmm I see....Im doing this because I basically zip tie the battery pack to my chassis since its slotted to help keep it in one place aslo I need to space the pack from the aluminum so it wont short.
Banned
Why dont you stop making stuff complicated???Just get a dam battery tray.If your going to do custom work, do it right.
Here:
http://www2.towerhobbies.com/cgi-bin...?&I=LXDBP3&P=7
That should work perfect.I was trying to find the ones from the old rc10s. Should just bolt on your chassie.Heres a pic for referance how it works...
Here:
![](http://www.racersparadise.de/images/big/dtxd12chassis-2.jpg)
FST, chill out please. No need to speak heavily, he was asking a simple question. jdm, I do think the foam would unnecessarily cause heat for your pack, not good. Heat shortens the lifespan of a pack. If the pack is shrink-wrapped, it shouldn't short. The only way to short it would be metal-on-metal contact. If you have metal exposed on the pack, use electrical tape to cover it safely.
I agree with the second guy. Heat is your worst enemy in electrics, besides if its a stickpack its already well protectedand already prone to overheating if it gets hot outside anyways
ON, CANADA
Does tower not sell those indy car things? I cant find a price on one but they look sweet and i want one.
My Feedback: (18)
As for the orginal question, how about getting some liquid electrical tape (walmart has it in the automtive dept., I'm sure lowes or a similar place would have it as well) and coating the chassis (actually, just the area where your pack goes) with that? That would prevent the pack from shorting out. Only problem is that it will probably wear down fast so frequent recoats would be necessary.
CA
ORIGINAL: NitroRunner
Looks like it's made by duratrax since it has a photon speed motor
Banned
IL
ORIGINAL: FSTlosiEVR
Here:
Here:
Banned
IL
ORIGINAL: gm72
My Feedback: (18)
How about using a velcro style strap instead of zip ties? That wouldn't damage anything, I use one on my B4 and if anything it puts less wear on the packs than the stock strap did.
WA
Banned
IL
ORIGINAL: KioIII
http://www2.towerhobbies.com/cgi-bin...?&I=LXLT68&P=7
would these work for you jdm?
My Feedback: (18)
Don't know if it will work for your car, but I used an 8 inch velcro cable wrap (they're for bundling up loose wires and such), I got a pack of six from target for like $3, works great, perfect size too.
Banned
IL
Nice I wont have to wait on those. Ill go check them out tomorw. It would work. Does it secure well?
My Feedback: (18)
Yeah it's pretty secure, it hasn't came loose or anything, weighs next to nothing too.
You might want to use two (or even three, like I said they barely weigh anything so it wouldn't really affect the weight) of them on yours though, seeing as the chassis has no walls or anything to keep the battery pack in place.
ORIGINAL: gm72
THNX
Duggy
ill give the guy a couple more chances but if he threadcraps again i will do that
and i apologize for taking this thread off topic...may it go back on topic now:P
THNX
Duggy
THNX
Duggy
WA
hey jdmkyosho.....let me know how everything turns out.....id like to see how you mount your battery
....so i can get an idea too!
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
