Check Point 19T Spec
I have the new Check Point 19T Spec. I have only had it out at the track once with 3 runs on it. My question is for any other CP 19T owners: what gears are you running? I have a T4 with the 87 tooth spur. I started with the recommended 19tooth pinion, didn't really seem to be the right combo, so I dropped to a 18 tooth, definitly not right. Last I tryed a 20tooth pinion, that seemed to have helped a bit. Just curious what others may be using.... On another note, it looks like Check Point are putting there 4 cell atlas brushes in the motor stock. I doubt they will last long. I may swap to the 6 cell infinity brushed when the stock one wear out. What are your thoughts so far on this new motor?
EdMan
EdMan
