30 series beadlock rims for rusty
WI
Where can I find rims like this. I am so tired of replacing tires/rims every other weak. I need some beadlock rims for my Rustler, and I like bigger rims w/lower profile tires. I can't even find any 30 series beadlocks but I seen them in a magazine so I know they exist. Also reccomend some good road tires to fit them. I have been using RPM claws with pro-line road rage tires. These seem to last the longest since I do a lot of on road high speed runs. I even duck tape the wheels and they don't last more than a couple weeks with the mamba 5700 and 3s 5000's. I have another question: do beadlock rims hold the tires on with power like this? I can't keep tires glued on very well, they seem to blow off every couple runs and I thought I knew how to glue tires pretty well. I have to reglue them often.
TX
RE: 30 series beadlock rims for rusty
Haha. I have the same problem with my tires. I'm using the 2.8" Anacondas in the rear, and one of the rear tires' edge partially ripped from the glued bead area, so I had to reglue it, and it still came off after a few minutes....
I can't say I've seen beadlocks used for high speed use, but if you tighten them enough, I guess it would be better than buying a whole new set of wheels as well as tires....
WI
The only beadlocks that I know of that will even fit a rusty are these. I have them and they are great!
http://www2.towerhobbies.com/cgi-bin...&I=LXRGT1&P=ML
WI
ORIGINAL: snellemin
If you want a bullitproof beadlock, check out RC4WD.com. I got them on my rusty.
NY
hey those 2.2 beadlocks do they also make them to accept pins for the losi XXXT, or are they hex, and if they are hex anybody know of any hex adapters?
TX
Those are the beadlocks from RC4WD.com. I got the nitro wheels setup. The body is the Pro-line crowd pleazer 2.0 Razor edition for a Revo 3.3.
TX
ORIGINAL: cheech4
TX
WOW! Those beadlocks cost more than my whole truck... Man I hate it when prices are so inflated... [X(]
But damn they look good!
TX
There is an alternative to those expensive beadlocks. There is an korean company that makes the plastice versions.....>>www.junfac.com/
