t4 tranny
I just got a t4 like 2 weeks ago and i was driveing it yesterday and then it started making a clicking sound coming from the tranny now if i hit the gas only one tire spins and if i turn the wheel that dosent spin the other wheel spins.Does any body know what broke so i know before i take apart the tranny.
thanks Mike
thanks Mike
KS
This is the enjoyment of rc.....its hard to tell without taking it apart. Have fun and keep us posted. be sure to check your diff trust spring tension and your slipper spring tension. it might be something as simple as that.
cody
cody
Do you have the manual for it? If so, adjust/tighten the diff to the specs stated... if not, crank it up until the plastic T-nut ( white plastic thing behind where the dog bone seats) until it touches the diff body, then back it off 1/4 -1/2 turn. It sounds like yours was, and still is too loose.
