Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
#1952
RE: Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
ORIGINAL: Lunchboxer
Did you see that I got an Unimog too now?! It will go on my shelf.. !!
Flower power paint job? There has to have been a flower power Unimog [8D]
#1953
IL
What?! That's not true.. I got a green Frog, blue Hornet, green LB, silver Touareg, etc, etc.
#1957
I saw these pics at RCCrawler.. does anyone try this type of setup on their suspension? Moving the rear upper links from below to the top of the servo deck?
#1958
That's supposed to lessen the torque twist, but the downside is that the prop shaft will be at an angle instead of being straight, and more prone to getting caught up on the rocks. Never bothered to try it since the original poster who did that went back to the stock setup
#1959
But you can extend the links to get rotate the axle to compensate so the driveshaft angle is not affected, right?! I wonder how that would affect the handling...
#1962
Yes you can use longer upper links or put spacers on the stock upper links to compensate, but then all it does is change the angle of the upper links and not the angle of the axle, I'm guessing it would perform the same as the stock setup?
#1963
Different length of links (top vs. bottom) will result in different geometry when the suspension goes up and down.. but I don't know how that would affect the performance / handling..
#1965
#1966
Bored at home.. bust the CR-01 to do some stunts.. (well, after all, my CR-01 has Willy as driver, so what do you expect?! )
http://www.youtube.com/watch?v=-lZVeqym6sg
#1971
I have my rear links on top of the servo tray although I used thinner spacers, probably about half that height.
#1973
It hasn't had any negative effect on the performance is all I can tell. I never really paid attention to how the rig worked before and then after
#1974
CA
A bit late but came home half buzzed and saw my baby sitting there calling for some work. I added the LEDs, mounted painted the grill, side mirrors, front pseudo blinkers and the light bar on the roof. I have the rack and other scale items but I'm too tired to do any more tonight. I also painted my new shell for those of you who remember I have a chopped shell as well but plan on building finishing that as my shelfer. Here are some photos I took with my run of the mill digi-cam, I really need to invest in a DSLR but for the money I dump into that I could buy more kits. Lesson I learned from LB's crash course on asset management
#1975
It looks great!! Got any pics of the LED setup? You are using the Tamiya LED controller, right? You got brake light too? Or?
