chargers
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (26)
MA
Hey guy's I'm sorry if it's been asked but I'm new into the electric thing I was looking at the maxxamps kit that has two 6,000 mah or the 8'000mah batts. with the charger that can charge and balance both at the same time but it's $500 for the 6000mah and almost $600 for the 8000mah I just didn't want to spend that much money if they were no good any feed back from someone that has any experance with this set up would be great
Thanks for all your help in advance.
David
David
PA
If you get the same mah of batteries you can charge them both at the same time on the duratrax ice charger. Make a Y to ave 2 deans connectors coming off the banana plugs, hook them both up and I set my charger to 4000mah, and 14.8v. I did this because I was charging 2 4000 mah eack 7.4v each batts.
