short range in stampede
velineon setup in a traxxas stampede good speed,after 25' or 30' stalling, several new locations,same result, the set-up is the original lay out.
ORIGINAL: slogan
I'd try a new RX if all else is good. Make sure your antenna doesn't come in contact with carbon fiber,graphite, aluminum, etc. What kind of batteries are you using, and do you have your lipo cutoff turned on? Maybe if your binding and geared too high, using poor batteries, it could cause the lipo cutoff to engage if its on, and you're using nimhs. Do you still have steering when it stops you?
the rx is new,the batteries check out,good.the pics shows the layout,anything needs to be changed? and yes i have steering when the signal is lost or the range is shortened.
You didn't mention what battery you're running. If you are still able to steer than you are not out of radio range. Sounds more like the VXL LVC issue.
Yeah, probably, get out your manual and figure out how to disable your low voltage cutoff. You say the batteries are good? If they are nickel metals and less than stellar, they could be getting sucked down while under acceleration to the point that would trigger the low voltage cutoff. Or, it could be a faulty speed controller. I seem to read alot about the vxl lvc not functioning properly, I don't own one personally.
ORIGINAL: 1maxdude
