'PROJECT' Quarterscale Pro Street Beretta
#52
IN
There are many brands of MIG welders out there under $200.00 And many brands of wire.... If you do purchase the H/F MIG... Just remember to use a good quality wire with it... The H/F wire is junk..... it's all snap crackle pop... very little weld wire....
Here is what I'm using....
WELDER>>>> http://www.harborfreight.com/cpi/cta...emnumber=94056
AUTO DARKENING WELDING HELMET>>>>>> http://www.harborfreight.com/cpi/cta...emnumber=91214
FLUX CORE WIRE>>>>> http://store.weldingdepot.com/cgi/we...ml?id=pfxNxXvg
#53
IN
The currant axle diameter is 5/16'' But i plan on machining the ring gear to 1/2'' I may even attept to cut slines in it at 1/2'' and use a split axle with slines on matching ends... Then i can build the 3rd member like the real ones... So needles to say I'm looking around for various cutters to cut them splines... OR>>>> I know of a few machine suppies sites that sell splined shaft collars that i may be able to weld to the gear... Then i will look for a matching sline shaft and cut it to length.... https://sdp-si.com/eStore/
The wheels are>>> http://www.cometkartsales.com/store/wheels/vank2.htm
Good luck on your rear end build..... I hope you have patience
ORIGINAL: troppo
Thanks for the extra pics mate, i was planning to use a toro rear end or maybe even a grinder head but seeing your work has given me the incentive to look into doing one from scratch. Just out of curiosity, what size axle are you going with? And what rear wheels are you using?
#54
Wish i could do the whole machining bit, welding and metalshaping/fabrication is fine but lathe or mill work scares the hell out of me lol.
I love the look of those wheels i reckon a couple of 4x5 inch would be spot on for the rear bags, pity they are in the states, postage would be twice the cost of the wheels, havent seen any in aus but i`ll contact them to see what they can do for me. Those splined shafts will be perfect for the axle, have to look for some over here.
Thanks for the links mate.
#55
ON, CANADA
qsp do you know of any kart tires with tread? like an off road style or rally?<div>
</div><div>anymore updates on berretta
</div><div>dont forget about me email.</div>
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#56
ORIGINAL: speedygonzales
qsp do you know of any kart tires with tread? like anoff roadstyle or rally?<div></div><div>anymore updates on berretta
Check here http://www.cometkartsales.com/store/tires/tires.htm its a follow on link from the link qsp gave earlier, this is it http://www.cometkartsales.com/store/wheels/vank2.htm
Cheers
Troppo
#57
IN
Why does a lathe/mill scare you??
I forgot your from down under... Here is the type of spline set-up i'm talking about... I'm sure i'll make something that will work good.... I'm going to build the 3 rd member like the real ones then... I also want to design it so i can change out the gears/ratios with ease...
You need to start a thread when you start building your rear end..
ORIGINAL: troppo
#58
IN
Hey buddy..... I haven't forgot about you.... i'll email you on that tomorrow.... Getting these final wedding plans all together has me pulling my hair out... Chass has been working some long hours soo i'm trying to do the bulk of everything.... I guess as long as i don't forget the rings i'll be O.K.![](http://www.rcuniverse.com/forum/js/fckeditor/editor/images/smiley/msn/teeth_smile.gif)
I spoke with a guy at our local kart shop about custom cutting groves in my tires and he said he could cut any tread pattern i needed.... So after the wedding i'm going speak with him again on them.... I really wanted to get a little smaller tire and new rims for the Beretta... The ones i have now are a little big.... But i think i'll just leave it as it is and extend the ground effects on the body once i start building it.... I want it to look super low to the ground.... Ohh yeah..... Picture that baby with them big meats tucked nicely under the body.... Love that look.... ProStreet all the way....
I haven't done much on the Beretta chassis... I'm trying to get this rear end built first... Then i will work on the upper strut braces on the chassis... and then i will build and weld in all my needed brackets... Then i will at least have a roller... I'm also going to build a nice steel fuel cell for it.... Yes i know what you probably thinking... It's going to be heavy... YEP!!! But i'm not going to race it... It's going to be more of a show car....
I have started on the face plate for the 3rd member and done some grinding on the rear end....
BUSY! BUSY! BUSY!
Here are a few other tires i have looked at,
BUSY! BUSY! BUSY!
#59
ORIGINAL: QSPSB2
I will be starting a build thread when i start building, but i got canned a couple of weeks ago and i`m having a hard time finding a new job. Research doesnt cost so i`m doing that right now and when i get a new job i`ll start buying materials for the build.
Congrats on your upcoming big day mate, hope its a great one.
Cheers
Troppo
#60
ON, CANADA
thanks for the tire links and pics.<div>the dunlop look attractive!!.</div><div>
</div><div>QSP like mentioned in email, I totally forgot about the wedding again congrats I know you have been talking of this since last yr
.</div><div>I love the fab pics, cant wait for more
</div><div>
</div><div>keep in touch.</div><div>Michael.</div>
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
#61
IN
Yeah buddy.... Always use cation while operating machinery... I have never injured myself but have seen many loose fingers/tips because they wasnt watching what they were doing... OUCH..... Sorry to hear about your job..... I own my own autobody/graphics business and it to has slowed down.... BIG TIME...... I wish you the best of luck on locating a stable job buddy.....Thanks on the congrats.... Can't wait to get it over... We have been planing this day for 2 yrs now.....
ORIGINAL: troppo
Well i havent done anything on a mill, and almost nothing on a lathe. When you dont know what your doing these things can bits and i hate being bitten lol
Cheers
Troppo
ORIGINAL: QSPSB2
Cheers
Troppo
#62
IN
Not a prob.... Well i now have the 3rd member base plate done... I will be starting on the pinion/bearing support soon... I also have the drain/fill fitting welded in the rear end now...
thanks for the tire links and pics.<div>the dunlop look attractive!!.</div><div></div><div>QSP like mentioned in email, Itotallyforgot about the weddingagaincongrats I know you have been talking of this since last yr
</div><div></div><div>keep in touch.</div><div>Michael.</div>
#63
IN
I took a few videos of the Sheet Metal Rear End today.... Performed two Ring & Pinion alignment test... I was suprised how smooth it ran for being dry... I have started on the 3rd member and will update on it as i progress....
http://www.youtube.com/watch?v=tzYCWYygHFM
http://www.youtube.com/watch?v=8AgqY_ydhD4
#64
That spun up nicely mate, is that the axle you`ll be using in the end or just a fill in one?
In the second vid it looks like theres something spinning around the back of the crown gear.
#65
IN
No thats a temporary axle... It's 5/16'' and I'm going bore the gear to 1/2'' And run a 1/2'' axle. The crown/ring gear has an spacer on the side of it... It's where the key goes... But the key was worn out and kept falling out... So i driled a hole in it and ran a bolt through it.... Welded nut on one side and was good to go... that what you see spining.... I'm going to build a carrier for the gear soon.... Thanks!!!
#69
IN
Thanks! These gears are from a angle grinder i purchased from harbour freight... http://www.harborfreight.com/cpi/cta...emnumber=93179 I'm just using these gears until i get my new ones from. http://www.ereplacementparts.com/
I purchased a few sets for the BOSCH angle grinders.. There good quality gears.... As far as them being capable of handling 18 HP.... I haven't a clue... I'm not going to race the Beretta so i don't think i'll have a issue with that.... I may open it up from time to time and do a few burn outs but thats about it.... I designed this Rear end with this in mind.... I can install a much larger/stronger gear set if needed.... The crown/ring gear in it now measures about 1 3/4'' and the opening in the face plate is around 3'' so i can step up to a much larger gear set if needed... I will also build a larger 3rd member as well...
I took the gears out and inspected them for wear last night... They still look awesome.... After re-instaling them i coated the gears with 5w30 engine oil and tested them again.... They did run much smoother... Go figure.... I have started on the 3rd member and will post more pics as i progress... I have the base plate done and will now mark it in relation with the crown/ring gear and cut the material away... I will then build & weld in the pinion support tube.. 3/4'' Water pipe... Then i will build/weld in the carrier support's & bearing caps...
Try to keep in mind.... The Rear End is far from being done... So it does look kinda crapy as it looks now... I still have alot of welding in the gaps & low spots in the case/mating joints.... It should look very sharp once done and all painted...
Quarterscale Sheet Metal Rear End Test #3
http://www.youtube.com/watch?v=MTLLU1jIrUw
My main page... I will be uploading as i progress..
http://www.youtube.com/user/QSPSB2
#70
IN
i've had a few PM.s asking me where i got my 4-link brackets... Well as i told them.... I built them... I am posting this so all knows just how i do this... i'ts very simple guys. All you need to do is print out the picture in the correct scale and cut it out. Then trace around it on the desired material... Then cut it out... Once you have all the pieces cut out close to the desired size... I cut all pieces about 1/8'' from the line... Then on one piece use a punch to mark the top hole...Drill the hole using a mill/drill press and do the same on the lower hole... Now once you have the lower & upper holes drilled.... Clamp all four pieces together securely.... all lined up in order as needed..I clamp mine down using a hold down clamp on the cross slide table. Drill the top hole thru all four pieces... Remove from clam and bolt together... Keeping all the pieces in perfect order....Now clamp it back down and drill the lower hole thru all four pieces. Remove from clamp and bolt together... Clamp back down to the table and drill the remaining holes... Now all four parts are identical...
Now remove both bolts and seperate the parts... Now grind the part to the line you marked on the part... Remember this 1st part must be correct... It will be your patern to follow while you grind/file the others from... Remove all burs from the parts & the edges of the other three... Now bolt the parts back together.. Keeping your 1st part the template on top... Now place the parts in a vice and concentrate on grinding the three biger parts to the edges on your top part... Now once you have all the parts ground the same, using a file, file all the parts level on all flat edges... Carefully file all the desired angles/corners as well.... Now once all the edges/angles look correct, remove from vice and remove top/bottom bolts... Now file all the burs of the edges of each part... Seperately... You will now have four identicle parts.... This method can be done any time you need more that one part...
This same method applies if you need to duplicate an exsisting part as well... Lets say you break a part... and can't locate a new one... Or there n o longer made... Then match up that part as you best can to the desired material and follow the same steps as above... Or lets say a part on your ride is a little weak and keeps bending... Then remove the part and follow the same as above on the desired material..
Even with little mechanical skills this can be accomplished.... I haver no choice myself.... When building an home built 1/4 scale car there are very little parts on the market that can be used... other than... bearings/hubs/misc parts etc.etc..
i'll post pics of these steps as well guys.... I am fully aware many of you know how to do this. But obviously some don't...
Good luck....
(((( Moderators... I hope you don't delete this... I think this could be some very usefull info for many out there that don't know how to make/duplicate RC parts..)))).
Good luck....
#72
IN
I now have the 3rd member pinion support welded in... And ran a few test runs on it.... I will now build the front pinion support.... I have uploaded some videos of the test here... http://www.youtube.com/user/QSPSB2
Here are a few pinion support build pics...
#73
You`ve said this isnt going to be a shelf queen but your not going to race it either. What are you going to do about the axle steer problems caused by the straight axle?
#74
IN
I'm really not to concerned about having any axle steer issues... The majority of the weight will be in the front end.... My front tires will also be the same diameter as the rear,,, So combined with proper camber i shouldn't have any issues.... But if i do run into an axle steer problem.. All i need to do is let off the gas in the rurns a little.... Many kart's have an axle steer problem running the live axles and thats what most do.... As do any car running a live axle.... To be quite honest the only time a live axle wont cause a axle steer problem is if it breaks traction...
Here is an interesting site regarding suspention geometry as well as many other interesting specs...
http://www.auto-ware.com/software/rsg/rsg.htm
