Great planes Fling 48" glider??
CA, AMERICAN SAMOA (USA)
I'm looking for a fun glider that I could toss around my house. The great planes fling seems to fit my bill well. I don't like that it doesn't have ailerons but that's fine... It's gonna be my first glider ( I've only flown gliders with motors. ) And I wanna ask that, do you have to catch it on a landing? Would 4 AAA cells combined together fit?
Has anyone any better suggestions? The kit would have to cost (max) a 100 bucks.
Paul
Paul
You don't -have- to catch any plane on landing. It's much safer to not even try.
The Fling should be a good airplane.
As for the battery fit, try it at the store with whatever battery packs they have.
CA
If you go to the "Cermark" website they give the dimensions of their various battery packs. From that you can figure out the cell size and go from there. I was looking at some packs last night for the "Quickflick" DLG I'm building and the pack with connector was only $10.00, so pretty reasonably priced as well.
How big is your battery pack?
How much support do you have for your neck?
How much sunscreen have you applied to your face?
Nominally with 2 standard servos, a normal 400-600 mah battery will let you fly well over an hour.
The little FLing is a fantastic airplane, it's wing loading is comparable to competition thermal ships, it thermals excellently, slopes pretty good, and is small cheap easy to carry around and even comes with a high start, Fantastic! Now the bad. The covering is junk, I recovered mine in Monokote, much better. The thing, fling thing???, is very small. Only the smallest equipment fits. 4 AAA might fit but I have a NiMh 300mA 2/3AAA rechargable pack I made in mine and it has 2+ hours off flying time. The push pull lines are some kind of plastic and I replaced them with Kevlar line. Out of the box it's a great airplane at a great price, I think every pilot, including powered airplane pilots, should pwn one to mess around with.
I see, I will get it then. Paul, I didn't said that "how long can I fly with that battery" I said how long can you fly without throwing it back up again
I will probably get a battery that they recommend.
Paul
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Paul
I suggest you not use AAA batts., they are way too heavy. Go with a small pack. I use a 5 cell 200mAH NiMH 2/3 AAA and last for a couple of hours. I also installed a throwing peg behind the bulkhead under the wing. Also under the tail I put a small tail skid to keep the elevator horn off the ground.
Regards.
Regards.
I still have a problem... lol. I dn't have a slow charger, only fast ( I've flown many parkflyers ( 3d), So I'd get that.
Heres the stuff I will get.
battery- http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHBB0
Charger- http://www2.towerhobbies.com/cgi-bin...?&I=LXCJE2&P=V
BTW what plug should I get for the charger. The battery has the "receiver" plug on it. And the charger has kind of a mini plug on it. Sorry for all the questons, but I'm more used to the deans ultra plugs and stuff.
Thanks in advance,
Paul
Thanks in advance,
Paul
ORIGINAL: SS2P
ORIGINAL: SS2P
... The battery has the "receiver" plug on it. And the charger has kind of a mini plug on it...
![](/forum/images/badges/premium_vendor.png)
ORIGINAL: SS2P
Paul
Paul
From a single handlaunch with NO thermal you can expect about a 30 to 50 second flight with careful flying. Hand launch glider is all about knowing the air and only throwing when you can feel that there may be a thermal around you. If you just toss it up without paying attention to the air you may toss it 10 or 40 times and never see a hint of lift. Especially if you're in a built up area with trees and stuff around you that makes it hard to feel what the air is really doing. If you're flying in this sort of crowded location then a glider isn't really the best option. For a glider to work well you really need a park like area about the size of at least a big baseball field so the air has a chance to smooth out and so that you are feeling what the thermals are doing.
Sensing and catching a thermal from the ground is not an easy skill to learn. It took me a good 20 years of on and off free flight flying to finally catch onto it.
The Reader's Digest version is wait for a lull in the wind and a general warm feel to the air. If you see insects or light airborne seeds drifting by and upwards then that's a bonus. This is the buildup. It signals that the thermal that is upwind is drawing in the air and this is what slows down the apparent wind. When you feel the first stirring of a "gust" or wind increase that is the time to throw the model. At that point you want to bunt out and turn right away so the model circles back around over your head or just behind you because that is where the thermal is.
From there you will find that there is about 5000 variations on this basic description depending on winds and thermals passing just over to either side. Have fun with it and best of luck.
Yep it will sure take some time. I will probably try my first flight with out any wind.
And I found exactly what I need! here....
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXWV18..
I will order :
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL430
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCJE2
http://www2.towerhobbies.com/cgi-bin...?&I=LXGVW2&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPT38 ---- I out of it![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPT46
I man, I can't wait to try it. To tell you guys the truth, all of my models ( mostly 3d) are falling like rocks down from the sky, when the power is off.
Paul
I will order :
Paul
I've been thinking here for the last week... I really want to get it but I'm not sure if it flys so well. Does the size affect the thermal hunt?
Paul
Paul
PA
It's really about the wing loading and it's very light on the Fling. I have had it in thermals that would take it out of sight and I would have to start diving it back down before it did. It has a nice shallow glide slope and it will handle pretty high speeds. The high start that comes with it will fall apart pretty fast. Mine did after a few weeks. The Sun seemed to break it down. I replaced it with 50' of 1/8!QUOT! dia black latex rubber tubing from [link=http://www.mcmaster.com/]McMaster-Carr[/link] website (part #5234K71) for about half the price of Tower. I put on 300' of light string and now it gets serious altitude in a hurry to get a great jump on finding a thermal. I can pull it back to about 180' and it shoots up like a rocket. I tried using a parachute later on and I really prefer the streamer. It is just easier to handle, for me anyway. Here is some video of some simple hand tosses where I was playing catch with it. Even that is pretty fun to do with it. Very nice glider IMHO. I do agree with Evan that the covering is not the best. If you try to tighten it up with heat, the seams at the polyhedral joints will separate. That's why I added the fluorescent yellow strips there to hold it together.
[link=http://www.yorkrc.com/videos/misc/Fling.wmv]Fling Video[/link]
I was able to mount a small panable video camera on it also.
Can you give me the site you bought the high launch from? I really would like one...
Paul
Paul
PA
The latex tubing I got from [link=http://www.mcmaster.com/]www.mcmaster.com[/link] is just the tubing. I used the split rings and stake that came with the Fling and replaced the 200' string with 300' of fresh string of the same type. It's also commonly used for kites. The black tubing is excellent and seems very resistant to UV from the Sun and doubling it to 50' really gets it up there. The part # is 5234K71. Just enter that into their search box. They have a huge product line for various industries and some good stuff for R/C as well.
p.s. It really makes it easier if you make some kind of reel to wind it up on. The flat board is a pain in the behind to unravel.
I just odered mine... Can't wait to get it.
I will use HS-55s, HFS-05S receiver 350 mah pack. Sounds good
Do you think the HFS-05S will have the correct range?
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
PA
I have the JR R610UL Rx and a 350mAh 4 cell pack in mine. I don't have any experience with the Hitec Rx, but as with any R/C 72mHz Rx, it should give plenty of range, at least farther than you can see the plane. If you want to be sure, you could always do a ground test a couple thousand feet apart with the Tx antenna fully extended. Someone would have to be with the plane to confirm you still have control. Maybe use hand signals. If you get that far on the ground, it work at even higher altitude. I doubt that I got mine much higher than 1500'. It's just a spec that high and nearly impossible to tell what it's doing. Talk about a rush of anxiety.
My Feedback: (12)
Yes, but you will want to replace the pull-pull string. Mine broke with just a little contact with the inside edges of the fuselage. I replaced it with spider wire from Walmart (in the fishing section).
I got mine too. I tryed to set the wing to 5-1/2 inches dihedral and it was correct but it moved away, after a couple of minutes. Now its about 13.5 cm. (had to be 14) Is this ok? or is it very bad?
Paul
Paul
ok. I will replace the pushrods with fishing line. I'm still not sure if I will replace it now or later ( when see if its wearing down.)
Overall I love the plane and I think the covering is fine. Not too bad. I'm almost done, just put in all the stuff (rx,battery, servers etc...
Paul
Paul
