Tail Rotor Question
Tail Rotor Question
A friend bought a new Blade 450X and he has a Specktrum DX7s. He asked me a question I didn't know and hopefully there is an easy fix that someone here might know. When he gives input to the tail...it will go right or left like it should but it won't go back to 0 pitch on the tail rotor unless he manually gives it input. He is not able to "bump" the tail input stick because it will keep going left or right until he gives it input back. Am I explaining this right? I am sure there is a simple answer....I have just never had this problem before. Any thoughts?
BC, CANADA
That is because the gyro is acting in Heading Hold Mode. It will do that on the bench, but in the air, once he points the heli to a particular heading it will hold it there. Just make sure to get the blades as close to center at take off which will help with the take off.
Also I would think one of the switches on the TX will switch the gyro mode from HH to Yaw Rate. In the Yaw rate mode the control will go back to center on the bench, but the HH mode will do as you describe.
