Repairing a Jetcat ECU
#79
RE: Repairing a Jetcat ECU
Hello
I'm facing thae same problem all is working on the ECU except the pump. I have changed all the param (voltage to make sure even with higher voltage it doesn't work) so I have tested the transistor that are ok does someone have a schematic of the ECU version 6 ?
I think the problem can't be a big one but without schematic I have to spend few day's just to build up a schematic trying to understand the connexions on the board and we have 3
One with the CPU memory and eeprom
the second is the high current output stage
and the last is all the sensors and i/O needed for that ECU
Or if someone has a last test to propose I'm ready to do before jumping in the transistor and AOP storry
Thanks in advance
Thanks in advance
#81
ORIGINAL: kalischek
Hello
Thanks in advance
Hello
Thanks in advance
#82
Hello
Thanks for your responses the pump run fine I have tested with 1.2V and turn fine
The transistors are ok I but i think there is a process that doesn't drive the transistor (a protection or ...)
I have done a mesurement with the scope and can see pulse coming 2 or 3 of few ms and than finish
I think there is a loop that control the current or ... I think i should have the schematic of the board because there is a pwm controler that will have in charge to control the voltage of the pump and I don't see anything when I try to make a test when I am in the test menu that is normaly used to purge the kero
If someone has some idea they are welcome I am electronic eng so i can understand and do a lot but if you don't know the state machine behaviour it is a little difficult
Thanks in advance
Regards
Thanks in advance
Regards
#84
P.S Diagram not for JETCAT but use the same type TRN.
#85
Hi all
i have the same ecu 5.0v and i was trying to start my engine when i notice a smok coming from the ECU so i take it a part and notice the no1 in the Picture was burn so i take it to my frinde to check it for me and he ask me to git another one so he can replace it . also hey find the no2 in Picture its short also. hey ask me to replace it too.
is that mine it have to do somthing togither .
also what is the part no for no1 in Picture .
and from wher i can order them pls.
thanks in advans
SAM
thanks in advans
SAM
#86
just for your info:
also the story start like this 1st:
My p80 that I have for a 1 year’s already
I tried to run it and its propene start so when the sequence start after the ignition and engine go to 5000 rpm there is a fire in the Combustion chamber the engine dos not spoall up and I think it’s the fuel dos not go to the engine so I take the fuel bomb out and tray it its work only when the volte go’s 0.600 and up but lees than that it’s not working when u tray to test it from GSU ….. Is that normal or it should work from a lower voltage
last time engine run was alomst 8 mintes.
and i didnt get over temp alarm. or the preheating
also i get acceleration delay
also its just run with propan only no fuel go to the engine
Thanks in advance
Thanks in advance
#87
We try to fix this problem sometime ago by looking at pictures but got no where. As for #2 looks like a 5v regulator try this web site. #1 could be anything,(JETCAT PART#) its up to your tech to determined if its a npn, pnp, two diode together or Fet. Good Luck
http://www.utsource.net/ic-datasheet/431AC-436378.html
#91
No sr
The only problem is I solder the lipo battery in reverse of + and - so when I connect the battery to the ecu it smoked and I open it there was a small voltage filter cheap burn so I replace it with the same no on the cheap and test everything is ok
So when I try to rotate the motor by the ground unite it rotate for 5 seconds and the smoke come from this bord in the engine as u can see in pic.
that the hole story.
And the engine was working fine before that
#93
Component name
The component is : YM78A diode smd
I have no Idea of the specs....
#94
Ym78a
Hello,
Same problem over here, this part burned out from my P80 after trying to let the startermotor run with a 2s lipo on the starter motor contacts.
I try to searth on the P/N YM78A, but nothing found, exist there an alternative P/N, or an other way to order this?
Thx guys.
Edwin.
Thx guys.
Edwin.
I've seen the picture now the component is a protection diode smd, it's burned because the motor was in non declutch or late declutch, this diode is used in case the o-ring and the motor remain clutched to the little purple spinner, the turbine run and the little motor produce current like a generator, and sent back current to the whole system smoking everything......
#95
My Feedback: (10)
basimpsn,
Thank you for sharing the schematic!
Do you have and would you share the schematics for the other boards in the ECU?
They would be a great resource.
Peter,
I tried to find a cross for the BYW20E and all I could come up with was a bridge rectifier in a rather large package.
Are you sure about the number?
Thanks, Whizbang
Peter,
Thanks, Whizbang
#97
ECU v10 short circuit problem
Hello firends,
I Bought a jetcat turbine, but when I plug another battery pack my ecu sparked, and it didn't work. I am electronic engineer, I opened the ecu pack, and I found a burned diode or Cap in input of circuit, I think this diode is for voltage protection, I take out the burned component, and Ecu work very well. but I want to buy that component and replace to burned component place, Is it possible for you to send that component number? I will buy it from here. that component is near power input
thank you in advanced...
#99
#100
