Jeti-duplex-ds-16-2.4-ghz
#2402
![](/forum/images/badges/trading_plus_member.png)
A CB400 is total overkill, I don't think you need that many channels? In a jet you could absolutely use the connection scheme that PuttPutt suggested, the load on the surfaces isn't that high in a jet compared to a giant scale airplane. I would still suggest to use a Powerbox Royal instead if you are still flexible on the equipment.
Thomas
Thomas
#2406
My Feedback: (39)
Just wanted to address the Jeti Central Box & Powerbox iGyro combination again that we spoke about a few days ago. Just noticed that there's an update since November last year that allows you to set the iGyro's output to digital UDI protocol. So now it's no problem anymore to connect your receiver(s) to the iGyro's inputs and the outputs go directly into the Central Box. No more complicated wiring and full protection of all outputs through the Central Box!
#2410
![](/forum/images/badges/premium_member.png)
My Feedback: (7)
I haven't exhaustively tested this yet but a quick experiment with 2, R3/RSW receivers, a Central Box 200 running the latest firmware which supports 24 channels doesn't show up in Device Explorer and the servos don't operate if PPM Positive, PPM Negative or UDI are selected. It only works if EX Bus is selected for the serial link on the receivers.
#2411
My Feedback: (39)
Wayne, probably there is an error in the Powerbox manual and they wanted to say that their iGyro can now output EX Bus and NOT UDI as they stated. This would make more sense, as I think that the EX Bus is the protocol that the receivers and the CB communicate with.
Because of exactly this old problem I have no Central Boxes anymore and switched to Powerbox products completely, but might change that in the future. The CB200 is a fine product, it's small, light and does have all the features I need.
I will ask this question in the Powerbox forum, I'm interested to hear what they say.
#2412
My Feedback: (7)
Still, due to the way the Central Box works, I suspect the iGyro will need to be connected after the Central Box with the iGyro controlling the servos directly. I think that no matter what protocols they input or output that will be the only way to have true receiver redundancy with the Central Box. That type of connection at least partially defeats some of the Central Box 200's benefits.
#2413
My Feedback: (15)
Question regarding the airspeed module:
I have the airspeed module and the pitot tube with the white and red small diameter tubing.
I need more length to get the tubing inside the fuselage as the pitot tube is on the wing in my A10.
1. Can I add to this without any error?
2. Can I calibrate it if I lengthen it?
3. I suspect keeping the airline ID the same would be ideal - can I get more from Jeti or Esprit?
DD
DD
#2414
My Feedback: (7)
DD
DD
If the Pitot is installed in a removable wing panel, rather than have connectors in the air tubes, use very short air tubes, mount the sensor in the wing panel and have a servo connector in the telemetry cable instead.
#2415
I have an airspeed module in my SM A10 and have extended by over half a meter, doesn't seem to make any difference.
Remember there is only the very slightest of air movement to operate the diaphragm.
m
m
#2416
AB, CANADA
Hey guys, I'm leaving the hobby for awhile so I've listed my DS-16 for anyone who wants a GREAT deal.
http://www.rcuniverse.com/market/item.cfm?itemid=1061526&electric=0
Sorry guys the Add says DC-16 but it's a DS-16 as shown in the picture.
#2418
My Feedback: (39)
Please post here once you find out as I'm interested in what they have to say too. This type of question comes up all the time.
just talked to the Powerbox guys, seems as if they screwed up a little. They thought it would work, but later on had to find out that it doesn't, because the Central Boxes definitely speak "EX BUS" only.
Thomas
#2421
AB, CANADA
Oh crap sorry guys. Nothing fishy going on at all. I put DC-16 instead of DS-16. It is in fact a DS-16. I always get that designation mixed up. I've edited the sales post on the other forums but of course nothing is ever easy on RC Universe.
#2422
Hi All,
I find the Voice file readout for the Mspeed airspeed way too long-winded.,,,"speed, one hundred seventy five kilometres per hour"...it just takes too long to complete....and on my jet I'd like it to be quicker.
I know its airspeed and I know the units (after all I chose them).....I think a simple statement e.g. "one hundred seventy five" would be much better.
Any thoughts from anyone - has anyone encountered this?
Also, is there a method to modify that voice file or use another one?...It seems to me that its built into the Mpeed software somehow.
thanks,
Leon
thanks,
Leon
#2423
Hi All,
thanks,
Leon
thanks,
Leon
If the system can not find the "EXACT" wav files it will not announce them... Hence just the numbers for your speed...
David
#2424
Hi David - can you please lead me through the Menu structure to find what your talking about....I can't find the file structure you describe above - sorry and tks - I'm not that good with the Jeti...
#2425
Once you you connect your transmitter to your computer through the USB cord you will see the content of the SD card displayed as a removable drive usually named as "No Name"
Expand that drive and you will see the file structure. In that structure there is a folder named "Voice". Expand voice folder and you will see series of folders for different languages. Expand the folder for the language you have selected in the configuration menu.
Once you expand the folder for the specific language you will see _Kph.wav etc... Then just change the name of the three files , Speed.wav, _kph.wav,and _kph2.wav.
Always remember to backup your files BEFORE making any changes...
David
