new r/c jet speed record.
For those not familiar with the crazy guys who fly on the backside of hills in strong winds using unpowered gliders the current record stands at 505 mph set on the 22nd Nov 2014 at Weldon CA.
I have done a little dynamic soaring and the skill level required is high, at 505 mph very high.
505 MPH or even 460 MPH is absurd. A slope soarer is limited to slopes and runs out of steam pretty quickly in straight and level flight if away from the slope. A jet, on the other hand could do some significant damage to someone's property if it gets away from the pilot. There is a reason real airplanes have triple redundant flight controls.
My Feedback: (22)
I'd like to see the flight where the record was officially set. I looked it up and the official record is 439mph. Still crazy fast, reason I'd like to see that is from what I remember the flight has to be a racetrack pattern with minimal height variation. The flight in this video wouldn't qualify as a record setting flight.
The pilot skill is impressive no question.
Respect for this flight is right there with Shui's flight with the firebird for fastest conventionally configured RC jet. I'd love to see these 440mph speeds on a jet that can taxi out and taxi back on it's own now
My Feedback: (49)
My Feedback: (30)
My Feedback: (49)
- The glider gains airspeed twice during the loop, when it pierces the boundary layer at an acute angle. Since the 180° turns retain most of the airspeed the glider completes the loop within the initial airmass at a higher airspeed.
- The gain in groundspeed occurs when the glider performs a 180° downwind turn within the moving airmass. Since the opposite 180° turn is done within the stationary airmass the groundspeed gain is not reversed.
Baically you do oval circuits in the rotor higher on one leg and lower on the other. TOP TIP practice with a a fast faomie first.
https://youtu.be/hFPJ6DUAY10 On November 22nd, 2014 at around 2.30 pm local time, Bruce T. flew a new Dynamic Soaring world speed record of 505 mph (810 kph) at the hill in Weldon, CA. He used a Kinetic 130 sailplane ballasted to about 26 lbs. The wind was between 55 and gusts up to 65 mph and temperature was 65 degrees Fahrenheit.
