Jet Central Sequencer help
Usually, all I have every had to do was rebind the Rxer to the Transmitter with the gear down. When you turn on the power to the Rxer there is a moment when the Rxer is not bound. If you have the wrong failsafe set, then the gear activates. If you are doing your failsafe in a powerbox, then you may have to reset the failsafe in the PBox.
