Aviation Jets SU-35
![](/forum/images/badges/trading_plus_member.png)
The SU-35 has been thoroughly tested and is now available for order by Pacific RC Jets.
Aviation Jet SU-35
Length 2750mm / 108.26"
Wingspan 1850mm / 72.83"
Turbines:
K85 X2 Non VT Non Slats
K120 - K140 X2 VT with Slats
The SU-35 is constructed using the composite fabrication methods from Aviation Jets practices, composite sandwich core technology and live hinging. The scale details on this SU-35 will be some of the best you have ever seen.
https://pacificrcjets.com/collection...18733182713952
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/20190218_153756_98250b95078055e35275ca6fb7ed135e55ecf6fc.jpg)
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/20190218_153809_890ac7d5de6426db97f9dd10a5f10d14d171cbe6.jpg)
Aviation Jet SU-35
Turbines:
NOTE: Turbine rail fit max diameter 105mm Thrust Vector only. All testing and number calculations where done with Kingtech Turbines.Vector version K120-K140Non vector we recommend K85-K100 2 K85 is plenty of power per factory, 7-8min fight timeDry Kit weight Vector version 13.5kg 29.7lbsDry Kit weight non vector 13kg 28.6lbsFuel tanks 87oz X 2Vector version with 2x k120 RTF flying weight is 25kg, 55lbs fueled.no vector, 2x K85 RTF flying weight 22kg, 48lbs fueled
Video of maiden and pricing available on our websitehttps://pacificrcjets.com/collection...18733182713952
