Jeti DS-12
#51
My Feedback: (53)
So normally manual cool down would involve advancing the throttle stick directly from low trim. Can't you simulate that by leaving the turbine control switch in the stop position ( trim low) advancing the throttle stick and then moving the turbine control switch to the run position ? Doing that should look exactly like advancing the throttle directly from trim low and trigger a manual cool down.
the person was saying that, he uses one switch for both throttle lock and idle up (which is trim
and Kingtech motor at least the guy I talk to at KingTech USA said -+100 and that work just fine.....
#52
My Feedback: (46)
‘Ok let see I don’t understand what that person was doing....first I don’t used throttle cut on the Turbine it servo zero purpose....we have brakes
I do on electric and Gas.....
) in that situation....you cannot just cool the motor...that’s all I was saying...
#54
#55
My Feedback: (7)
Sorry but you're contradicting yourself. Read your post, which I originally replied to again. You said if you use throttle cut and throttle idle on the same switch you can't start manual cooling. I'll try to explain again how I think you can.
Switch down - Throttle cut -125% = TRIM DOWN / STOP
Switch up - Throttle idle ~20% = TRIM UP / READY
Normal start - Flip the switch to TRIM_UP/READY position, Turbine is ready, advance throttle and it starts
Normal Shut down - Flip switch down, Turbine stops, normal cooling cycle starts.
If for some reason following normal shut down the normal cooling cycle doesn't start:
With switch still in the Shutdown position (TRIM_DOWN) advance the throttle and then flip the switch to RUN. When you flip the switch to RUN the turbine will see the throttle channel transition directly from TRIM_DOWN to full throttle and start the cool down cycle
OR you can do a REAL manual cool down and grab a leaf blower.
I don't recall anyone saying +/-100% doesn't work fine, just that if your turbine has already done TEACH_RC using Spektrum; if you set your Jeti end points to +/-80% you don't need to repeat TEACH_RC.
#56
My Feedback: (53)
I’m out of here....
#57
So, since I don’t use throttle trim buttons on any of my electrics or turbines, was wondering if anyone has come up with a use for these unused trim buttons.
For instance I know some use them for nose steering trim
#60
#63
I have found cross control trims to be very useful ... e.g. you can fly with your right hand while easily trimming with left hand on the left side trims. Just be careful when you first start using it so you’re trimming what you think. You’re trimming!
I do not use a rudder trim ... composite jets should never need it (Except perhaps thrust vectoring) and I use the right side L/R Trims for steering. I do not use the up/down on right side ... I use on/off locking switch for turbine on/off.
JS
JS
jlovitt (07-21-2020)
#64
JS
JS
#65
JS
JS
#66
My Feedback: (53)
For the auto trim I also make a sound event repeating (choose a long delay) so if it get selected you know about it.....(To use auto trim think straight line...and beep the stick much easier that way)
#67
It may have been stated already but bears repeating ... I highly recommend that you setup flight modes on your 3 position flap switch and set your trims for aileron and elevator to flight modes. That way when you trim in one flight mode (e.g. flaps down) it does not affect your trims in other flight modes (e.g. flaps up). Once in the air you just trim the jet with the trim buttons in each of the flight modes and you’re all done. You can still of course replace the trim with elevator offset later if you want, but why bother.
There are many ways to do flaps, but using the butterfly function is the way to go in my opinion. HarryC has it covered in his videos. Butterfly also makes crow very easy to employ if you so choose.
Honestly, for the most part I found Jeti setup to be very similar to Spektrum DX18 and similar, but just a few things that you just have to know via friends or videos. E.g. LOGMAX to make the butterfly system work on the flaps, etc. Otherwise the general principals are very similar, e.g. flight modes, servo setup, etc. Jeti just gives you more flexibility to do it simply and more like you want it, e.g. switches, etc. It was not nearly as hard as I had been fearing from people who were anti-Jeti for some reason ... you can keep it quite simple or make it as complicated as you want.
JS
JS
CraigG (07-22-2020)
#68
Thanks for the youtube hints guys, I have now made quite a few playlists, and ordered the videos within them. It should make it much easier to find what you want, click the playlists button and choose the theme you are interested in.
#71
I was thinking something like that the other day, I had the opportunity to assemble and set up a KinCat using a DX18, it was very enlightening to learn Specktrum, even though I liked Spektrum a lot, my sight has been on Jeti for a long time now.
jsnipes (07-21-2020)
#73
My Feedback: (20)
I use cross trims and flight modes just like Jamie mentioned above. I highly recommend flight modes, cross trims, and flight mode trims. Just be sure you set it up correctly before you fly.
The small trim buttons were hard for me to feel till I found these "Trim Hats." The trim hats attach to the buttons with small circles of double sided auto trim tape. They are easy to attach and very solid feeling. With a strap or tray I can just fly with my right hand and trim roll and or pitch with my left hand. The trim hats are very easy to feel and they work just like a trim button on top of a fighter stick. May not be for all but I really like them.
Gary
Gary
#74
I saw them before, I think they can help find the trims jusy by feeling ypur way around them, will definitely check them out, as it is, I ordered a set of stick ends with wider ends, a few times before I found myself with almost a hole on my right thumb after an energetic flight.
#75
My Feedback: (46)
Harry, thanks for setting up the playlists! So much easier to find the videos now. I have to say your videos are gold, there’s so many features in the programming that I don’t know and I’m going on year 3 of Jeti. There’s a lot I keep saying, yeah I’ll figure out how to use it someday, like auto-trim and Lua. I just watched your vids, no further research necessary on auto-trim and Lua. Well Lua there’s a lot to play around with so I will do more research as to what I want to use. What’s also great is you go into detail on every setting applicable to whatever function your explaining. Really helpful, thanks!!
CraigG (07-22-2020)
