Turbine oil amount
My Feedback: (41)
Oh for crying out loud...... the rate these Turbines burn fuel, it's time to get yourself some five gallon containers for your fuel. I prefer the semi'clear versions with large screw on tops with handles to carry them in one hand, and air vents. Makes 'em easy to fill and mix the quart of Turbine oil in as you fill the jug and I ALWAYS use a biocide as well as an anti-static additive. Then it's really easy to see if you should happen to develop some of those nasty fuel system clogging "bugs".
The following 3 users liked this post by Ceeray:
