HELP: JetLegend F-18 1:7.5
HI Guys. Attached pics of my jet. I was hoping someone could assist with the following questions:-
- Is this the jetlegend F-18 1:7.5 Airframe? or some other brand. I have attached pics for reference.
- Does anyone have a manual for this airframe to share with me.
- What is the actual CG that is indicated in the manual for this jet?
- What is the best/actual CG pilots have used on this jet to ensure its stable.
- Do you guys setup the elevator and aileron separately? OR is tailerons recommended (elevator/aileron mixing) for best performance/control?
- What was your default Elevator position for straight line flight?
- I am assuming 14kg is minimum turbine requirement for this jet as I have read elsewhere.
