F-16XL ARF by Global Knight Models from Global Jet Club
Yodes65 (05-07-2022)
#505
i have also 7.4V regulated and nose gear wont retract properly with JP controller if airpspeed builds up. Mains go.
Also braking really uneven. I use 3S from engine for brakes and I sure hope the lgc15 would solve these issues.
Also I am thinking putting some padding behind brake pads to keep them in close contact with magnet, so they will act faster without locking up.
#506
Thanks!
Tone
#508
Good point! I will have to get the power from 7.4V regulated for all. Easy tho as I just plug 3 ports from AR smoothflite and get 3x5A constant..
Gear can handle 3s lifepo4 9.9 but not 3s lipo. Thats from Jean Marc / JMB
#509
My Feedback: (20)
That's the problem I had with the LGC-15. It has no ability to deliver different volts to gear and brakes. I needed 3S on the brakes to stop the jet but the JP retract motors were limited to 2S. This info came from JP and is also printed on the JP gear controller. I removed the LGC-15 and used the JP gear controller on 2S for the gear only. I then installed an AG-63 steering and brake controller and used 3S for the brakes only. It worked great and steering and braking were perfect...until the brake output failed after about 6 months. I installed the JP brake controller on 3S and it lasted 1 flight and failed. It internally shorted out and was cooking when I finally got to the jet and smelled it burning. I plan to install another AG-63 when I get back to it but I'm so frustrated with the JP gear and brake system it's in the penalty box for a while.
#514
My Feedback: (20)
Gary
#516
My Feedback: (20)
My F-16XL after the last flight of the day at Flying Tigers Event Of The Year 2022 in South Carolina. Its' flying as good as I can fly it and the new AG-63 steering gyro and brake controller on 2S seems to be working well so far. I did not realize till I posted the photo that I was photo bombed by the landing PAU Edge in the back ground!
This has to be one of the most fun jets I have flown. It flies fast, slow, will turn up it's own rear end, and is easy to land...plus it just looks good flying or sitting. I really like it. I looks like the V2 by Air Knight in the above post has fixed lots of the V1 issues and should be a great jet.
Gary
The following 2 users liked this post by Viper1GJ:
Afterburners (11-18-2022),
mongo (11-18-2022)
#519
Yodes65: Nice video of your XL. I have had one for well over a year and have not flown it. Long story, but just got discussed with the build and now the main gear does not seem to center correctly in the Fuselage, so that means I need to take the entire thing apart, again. But your video got me excited and now I started looking at it again. I have probably asked this question and it has most likely been answer. But how do you have your control set up? Separate elevators and ailerons, or work together like elevons, Hey thanks for the info.
T. Green
T. Green
#520
T. Green
T. Green
And Yeah, I know rhe pain. My hanger 9 P51 is languishing unfinished because if gear issues. Apparently eflite lg don't like xicoy lg gear controllers.
#521
thanks for the link
TG
#522
My Feedback: (20)
Gary
#523
My Feedback: (20)
Just finished a fun weekend with the XL. Sorry no more pictures or video. I moved the CG back a little by shifting one of the Rx batteries behind the cockpit. I then concentrated on flying a slower final turn and final approach at higher AOA than before which made slower more scale like landings. It looked really cool. It is really fun to fly and easy to land.
