PST 600 enought for a rookie?
QC, CANADA
I wonder if a PST 600 is enough for a ROOKIE ..-COMPOSITE- ARF ask for 8kg to 12 kg ..and the PST got only 5.5 kg the pst 600R 6.5kg i am sure i say one rookie with a PST 600.....please give your idea!
RE: PST 600 enought for a rookie?
I have personally flown the PST / WREN size motor on the Kangaroo, AV8R, BobCat, BVM F86 and HotSpot. Very good performance with 50 - 70 oz of fuel onboard. I would compare it to a good old pattern ship ( Dirty Birdy, Curare, etc ) You would be surprised what 12 lbs can push around!
Dean Wichmann
www.helijet.ca
Dean Wichmann
www.helijet.ca
You are most welcome in Thailand especially at PST Jets!!
Even the J600 is more than enough for the Rookie. J600 with Kangaroo clocked at 290kph. The lastest Rookie with J600R flown at top speed of 300+kph...scarely speed and you will automatically throttle down. These jets are very slick and will move very fast with 12lbs+ turbine...
B777
B777
Yes..high speed passes were from a shallow dive. I just kept the radar gun pressed to record the highest speed. The radar gun was pointed directly at the jet coming in and just let the aircraft pass by. Actual number for the Kangaroo was 292kph and most of our jets are averaging 270-280kph. I use Applied Concept Stalker radar gun.
B777
B777
