Jet Cat P-120 min RPM questions
My Feedback: (21)
IL
I have a P-120 in a Roo. I know there is a chart on the web site to turn down the max RPM for lighter airframes. My question is can I turn down the idle RPM?? If so is there a min value that this should be?? The problem is that I am using the brakes alot to taxi, and using my air up.
Bill
Bill
My Feedback: (8)
RE: Jet Cat P-120 min RPM questions
Bill, the low idle rpm is 33,000. It really can't be set much lower because of the possibility of a flameout. This is the factory default setting for idle as well.
What aircraft do you have it mounted in? If it is real bad you might consider a smaller motor. I know you probably didn't want to here that, but that is about the only way to decrease your residual thrust.
John Redman
Team BVM, JetCat USA
JetCat USA Janitor (Mr. Matt's old job)
John Redman
My Feedback: (20)
ORIGINAL: John Redman
John Redman
John Redman
My Feedback: (44)
A little TOE IN will help in reducing the roll. Also, you can tighten your wheels a bit, just make sure they are lubricated very well or they will heat up and seize!!!
