BVM F-86 test flight
My Feedback: (21)
IL
I am getting ready to test fly my new Sabre. It is powered by a p-80. Wondering what most of these weigh with p-80s. Also how much nose weight is needed to balance it. Any other tips or suggestions for the first flight would be great...
Bill
Bill
NC
RE: BVM F-86 test flight
I've heard weights from 15 to 18 pounds depending on builder and onboard accessories. You should not need any nose weight if you position your receiver battery pack up front. We are using 5 cell, 6volt packs. Play with battery position( on top of inlet ducting) until you get the correct CG as suggested by BVM's plans. Plane flys great, don't worry about the first flight.
Be sure to have suggested elevator throw on high rates.
Good luck.
Good luck.
My Feedback: (9)
My BVM F-86 P-80 with wing tanks, scale cockpit and detailed paint scheme weighed 19 lbs. dry. Mine balance right on c.g. with two 6 volt rx packs in the nose and that heavy full bodied BVM pilot. The plane flies very sweet. Matter of fact mine did not require a single click of any trim to fly hands off. My only word of warning is that at the beginning of the flight when all the tanks are full, especially the single rear tank, try to stay away from any manuevers that would require "hard" elevator pulls. This plane will snap/stall. The good news is that they recover very easily when you point the nose down & wings level. We had two of them here built w/P-80s and both of them flew identical. After a couple of minutes into the flight you will notice how much it will lighten up and reduce the chances of an elevator induced stall/spin. My buddy typically flew his without filling the rear tank. My plane was absolutely ballistic with a P-80+. If I build another it will be with a P-60 or JB-50 to keep the wing loading down. Good Luck and happy flying.
Mine is a delight witha PST 600R and C of G as per specs. Rock steady flying, not overpowered, (nor was the real F86) and lands beautifully. Needs a fair bit of thrust in the landing configuration. Not noticed any tendency to stall-flick and pitch response in early part of flight is a little reduced, just right after some fuel is burned off.
Regards, David Gladwin.
