Deltron 2000 DMD question
My Feedback: (39)
RE: Deltron 2000 DMD question
Matt,
We still spray the old DBU base/clear system. It uses the DMD mixing bases with intermix DBX695 and DRR reactive reducers. I think you can spray the DMD straight without an intermix (they have one for DBC, I just don't know the # right off hand). Just reduce it with straight DT reducers according to humidity and temp. I spray all my planes with DMD bases and DT reducers. The clear topcoat will set the colors.
On another note, red pigments use to cost the most, but we now have a blue toner that costs $165.00 per quart.
Hope this helps,
Ron Ballard
Hope this helps,
Ron Ballard
Matt,
You will need to add a binder to the mixing tint as it will not dry properly if used as is. There are specific mixing ratios of binder to tint. The ratios vary quite a bit, so it would be a good idea to check with your local auto paint supplier. He can look up a formula that uses mostly the tint you have and use that ratio. When I mix up custom colors (not a formula from a factory code) I go with a ratio of about 1:1 tint to binder. I'm currently using Dupont paints in my shop so I'm more familiar with them. I have used PPG in the past though and the mixing ratios are similar. One of my suppliers sells PPG so if you have any trouble getting help let me know and I'll get a ratio for you.
Chris
Chris
My Feedback: (39)
Matt,
I just came to the shop to look up the intermix # for DBC (binder is another correct term).
It is DBX1689 basecoat converter. For small applications you can spray DMD with DT reducer, however, for larger areas it is advisable to do as Chris suggested, intermix or bind the formula.
The DBC lays out much flatter (more even, less peel) than DBU, which is why many choose this over more conventilnal (older) finishes. DBC was developed to compete with the foriegn market
where most auto finishes are smoother, less peel- than say a GM pickup truck finish.
Good luck,
Ron Ballard
Good luck,
Ron Ballard
