ECU for used turbine
CA
Hi Pilots,
does anyone know who makes a ECU I can use for a Sophia 850-it is in good shape and I would like to run it. I just want a simple one that senses EGT and compressor discharge pressure to control the fuel pump- I will use air pressure to start it-so a real fancy one(read expensive) is not needed.
Thanks,Jackjet
Thanks,Jackjet
Jackjet,
You might give either Antonio at Mini Hobby ATL a call or Andy Lowe at Electrodynamics. Antonio used to make an ECU for the Turbomins, and I think JPX engines. Andy used to make the RAM ECU.
David Reid
David Reid
Simple ECU
Jackjet,
You might want to take a look at Gaspar Espiell's pressure and temp sensing ECU. This is the one that comes with all Artes' KJ66 turbines.
His website is: http://www.espiell.com/inicia.htm
Chris
Chris
