FC F-86 Struts
FC F-86 Struts
I am currently building a FC F-86. The gear struts are Robart but the springs in them are very weak, I don't think they are the original Robart springs. The struts can be compressed with about 5lbs force. the result is that the bare airframe weight will bottom out the struts. This is quite useless and Imay as well have solid struts. So I want to replace the springs wing uprated ones. But what rating should I use? I seem to recall some learned peson once proposing a formula for this purpose based on the models weight. I am expecting the model to weigh in at around 25lbs. Can anyone shed any light on this problem?
John.
John.
RE: FC F-86 Struts
seems to me that this is due to scale appearance, as when lowered they sit that way on the ground, i have buiult one of these and used stock gear.
regards, fred
regards, fred
RE: FC F-86 Struts
Thanks Fred,
Yeah I figured that was the case but I had to cut my struts down 8mm to get the wheels in the wells. If the model is sat onits wheels now the struts bottom out and it then sits nose up. I think that the struts on the full size F-86 may have extended slightly as they retracted.
How have you found them if you are using the stock items. They must give you no shock absorbtion at all? Any issues with them in use. BTW, which colour scheme did you use? I am trying to fnd details of the Argentinian Airforce display scheme.
Regards,
John.
Regards,
John.
RE: FC F-86 Struts
hello john!
well, indeed the gear extend a lot on the real thing to reach the fuse bay! i didn´t have to shortne it, as far as i remember...
shock absorbing is almost nothing, for shure, i only have extended the coils a little more, to have more pressure. the planer fley only 4 times, no issues until now, this doesenpt belongs to me, i´m a pro modelbuilder...
i have done it in JASDAF colours, and custom made the stencils for her
for argentinean scheme, try to reach Gustavo Campana, he lives there, have done one in that scheme and probbably will help you, he is very gentle and nice guy!
if i can be of further help. ask me!!
RE: FC F-86 Struts
[8D]WOW! She looks really, really nice. I have about 1 million question that spring to mind and I may take you up on your offer and email you at some stage. I am hoping to do a really good scale model but you seem to have set the bar pretty high. I will try and look up your friend as an Argentinian scheme would be unusual in Europe.
I love the drop tanks by the way.
Regards,
John.
Regards,
John.
