searching for hinges
RE: searching for hinges
The KAVAN flat pin type hinges will come apart from what I can remember. The end of the pin is crimped but can be pulled out if required.
I will have a look next time I am in the workshop.
Why do you need to get it apart?
You can also buy "sockets" for the Robart pin hinges (e.g http://www3.towerhobbies.com/cgi-bin...?&I=LXES25&P=7)
You can glue the hinge into one surface, the pocket into the other, and use a grub scrw in the socket to hold the hinge in.
My Feedback: (15)
Thanks guys.
I am putting my hinges in an F22 and fitting the aileron or flap into ail or flap slot, where the acute angle of the slot relative to the wing trailing edge is tight with Robart hinges. It would be simpler to have two hinge pieces and then line them up and then place the wire.
Dave
Dave
