Whats the size of Yellow Aircraft F-16A
RE: Whats the size of Yellow Aircraft F-16A
It's all here:
http://www.yellowaircraft.com/jets/f16.htm
Length:......................56"
Wing Span:................44"
Weight:.....................9-11 lbs.
I have seen the facts on Yellow Homepage, but I dont think that 56" in length can be correct, not if it is a 1:9 scale
ORIGINAL: R_Belluomini
It's all here:
It's all here:
that is their current C model, the old A is a 1/9th scale.
come on Bob, i know you remember the old A that didn't have the gear doors???
Opps yes the length on the web page is wrong it is 67" not 56"
Look here: http://www.yellowaircraftplanes.com/...F16_Specs.html
This is for the current "C" model I think the "A" was the same scale.
My Feedback: (8)
FL
I just bought a Y/A F-16A RTF. The fuse is 66 3/4" long. and the wing span is 44". I also have a new in box Y/A F-16C (polyester green fuselage) and it is the same length/wing span.
Sean
Sean
FL
Sean,
Did you by chance get instructions with the A model? I have one I need to build but there doesn't seem to be a whole lot out there.
Regards, Bill
Regards, Bill
