Tamjets f-16 powered by a Wren 54 Mk 4???
I will be picking up a second hand Tams composite f-16. I have a Wren 54 mk4 putting out around 15 lbs of thrust. Will this engine be enough to fly the 16 decently?? Mind you, I will be flying in Denver as well where I guess I should expect a slight decrease in thrust. Any info. appreciated Thanks Jon
I have seen them fly with P60, which put out only 12-13 lbs of thrust. Max speed of 150 mph on straight and level flight upwind.
![](/forum/images/badges/premium_member.png)
AB, CANADA
Past tense for the Wren...it is now in the boomerang. A P-70 in now in the F-16 which makes it even more fun!!!! Sorry for the confusion.....
